RV.Net Open Roads Forum: Class C Motorhomes: Are all RV's noisy and rattle?
 > Are all RV's noisy and rattle?
jgalvin44102
Home
Posted: 06/30/20 11:13am Link  |  Quote  |  Print  |  Notify Moderator
Just a general question - My wife and I rented a well used 150k mile class C for a weekend trip from a private owner. We loved the conveniences while running down the road but it was a serious rattle trap. The RV was in great shape for its age and was well kept it seemed but was really loud on rougher roads - loud enough that you couldn't have a conversation. Is this normal? It was our first time in a chassis model camper, we have a pull behind toy hauler currently.
I realize that is a lot of miles and things wear out and loosen up but I am just curious if that's the norm in the newer units too?
carringb
Corvallis, OR
Posted: 06/30/20 11:29am Link  |  Quote  |  Print  |  Notify Moderator
My sister's 2020 Forester only has two rattle sources: The stove cover, and the ladder storage hooks. The stove was solved with a dish towel. Otherwise, it surprisingly quiet. Except on bad gravel washboards. Then everything shakes and makes noise. Most of it is probably pots/pans/furnishings etc and not the coach itself.
There's huge differences in construction methods, and fit & finish, which surely makes a big difference.
Also, do you know for sure the body was original to your chassis? For a long time, Cruise America used to swap old bodies onto new chassis. Until they finally realized the chassis is the longest lasting component. But I think they did this though the mid-2000's.
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
ndrorder
Southwest
Posted: 06/30/20 11:31am Link  |  Quote  |  Print  |  Notify Moderator
Some rattle more than others, but yes they all rattle. The RV of an owner more sensitive to the rattles, rattle less.
__________________________________________________
Cliff
2011 Four Winds Chateau 23U
Captain_Happy
Pahrump, Nevada
Posted: 06/30/20 11:32am Link  |  Quote  |  Print  |  Notify Moderator
These things aren't Cadillacs.
pianotuna
Regina, SK, Canada
Posted: 06/30/20 11:38am Link  |  Quote  |  Print  |  Notify Moderator
Hi,
I added air tabs. The noise level from air rushing past the RV dropped dramatically.
Regards, Don
Matt_Colie
Southeast Michigan
Posted: 06/30/20 11:49am Link  |  Quote  |  Print  |  Notify Moderator
I was shocked.
We had unloaded the coach for the winter, and then I needed to pickup the boon for a friend's sailboat. I can fit 13'6" in easily, but do not have a truck. So, I drove the coach.
Without all the stuff in it, it was a lot quieter than usual. We do separate pans and stuff so I don't know what all that noise was, but it was gone.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs going to see some dry places that have Geocaches in a coach made the year we married.
IAMICHABOD
Sunny So Cal 90713
Posted: 06/30/20 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
As most have said they all rattle some depending on what is on board, tire pressure and such,some worse than others.
As I was looking for my next RV a few years ago I found them all on a Ford Chassis,they were all noisy, some worse than others.
I then found one on a Chevy Chassis, the difference in the noise levels inside was remarkable. The ride of one on a Chevy chassis in not as harsh as one on a Ford Chassis,making it more quiet,less banging around of all onboard camping gear.
This was a big selling point for me.
Former El Monte RV Rental
Buying A Rental Class C
Chevrolet Based Class C
MDKMDK
Canada
Posted: 06/30/20 01:40pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, they all rattle. Some more than others, as was mentioned.
Mike.
2018 (2017 Sprinter Cab Chassis) Navion24V + 2016 Wrangler JKU (sold @ ????)
2016 Sunstar 26HE, V10, 3V, 6 Speed (sold @ 4600 miles)
2002 Roadtrek C190P (sold @ 315,000kms)
IB853347201
Eastern Ontario
Posted: 06/30/20 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
I can't speak to others but our class A is quiet when traveling down the interstate at 70 mph.
When we first started out we had a Class C on the Ford econline chassis. Drove like ****, was extremely noisy.
Touring in our 2010 Suncruiser, beaches, site seeing, national parks, chillaxing..
VA-Apraisr
glen allen, VA
Posted: 06/30/20 01:46pm Link  |  Quote  |  Print  |  Notify Moderator
I put the silver bubble wrap on all the insides of my cabinets, moved the grill to the storage bind below the camper, and put foam padding between the dishes. Used an old flannel sheet and cut to size to wrap around the pots/pans so they don't jiggle. Used to be unable to talk while driving; now it's just like a normal car ride. It's amazing what can be accomplished in a few hours. The screened door was a big culprit...never used it much so I just cut it off the hinges. Keep things out of the shower floor....move them to the center of the bed or above on the cabover bed. Same goes for the kitchen sink!
