RV.Net Open Roads Forum: Travel Trailers: Black Water Accident
 > Black Water Accident
Bird Freak
Dallas Ga.
Posted: 06/30/20 04:26pm Link  |  Quote  |  Print  |  Notify Moderator
Mickeyfan0805 wrote:
If I am reading your story correctly, I think you answered your own question. You state that you opened and closed your valves to lubricate them prior to your trip. In doing so, any remaining fluids/chunks from your last dump, plus the antifreeze that you had put in your tank to winterize, would have poured down the tube and filled up the space between your valve and your outlet cover. When you closed the valve you sealed that space, trapping the fluid between the valve and the cover. When you removed the cover, that pressure and fluid would have been released the - hence the unpleasant shower.
We've all been there in one way or another! Happy trails!
WINNER!!!
[emoticon]
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
wildtoad
Blythewood, SC
Posted: 06/30/20 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
If you had waste matter in the pipe the waste is still going to decompose and generate gas. When you loosened the cap the gas and stuff found a way out. Been there.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
opnspaces
San Diego Ca
Posted: 06/30/20 05:17pm Link  |  Quote  |  Print  |  Notify Moderator
I second the cap with a garden hose attachment. I have one and I always carefully loosen the small cap and make sure there are no leaks before I remove the larger cap.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Turtle n Peeps
California
Posted: 06/30/20 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
Things I have learned while dealing with the black tank over many years:
#1. Always treat the cap like a loaded gun. Never stand or put any part of your body in front of it while taking the cap off. EVER!
#2. Always act like there is raw sewage between the slide valve and the cap.
#3. Put the open end of the hose under the cap outlet so even if it has a few drops of goodness it falls in the hose and not on the ground.
#4. Always have a gallon of bleach around in case something happens.
That's my advice and I'm sticking to it!
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
Two Hands
California's Central Coast
Posted: 06/30/20 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Please, don’t ever tell that story again!
2015 Fleetwood Excursion 33D
2016 Grand Cherokee Limited
Retired Law Enforcement
U.S. Army 1965-1973/RVN 1968-'69
I am the frequent recipient of "Get out of the way old man!"
mooky stinks
Cicero,NY
Posted: 06/30/20 08:25pm Link  |  Quote  |  Print  |  Notify Moderator
And that is why I have a clear 4" extension on my sewer pipe!
Wishbone51
End of the Oregon Trail
Posted: 07/01/20 12:25am Link  |  Quote  |  Print  |  Notify Moderator
I did something similar on my first RV trip .. Opened the lid and made a mess. Not on my face though .. Must have been debris stuck in the valve, and it never happened since .. To make this funnier, I thought it would be good time to have my son learn the ways of the black tank. He would never help me dump the tanks again.
2017 Jayco Jay Feather 25BH
2004 Nissan Titan
valhalla360
No paticular place.
Posted: 07/01/20 04:13am Link  |  Quote  |  Print  |  Notify Moderator
mobeewan wrote:
Oooopsies.
No...Pooopsies [emoticon]
Tammy & Mike
Ford F250 V10
2008 Copper Canyon 5er
Catalac Catamaran 34'
Full Time spliting time between boat and 5er
Jebby14
Windsor Ontario
Posted: 07/01/20 04:14am Link  |  Quote  |  Print  |  Notify Moderator
nasty.
ZINGERLITE
Union Lake, MI
Posted: 07/01/20 05:19am Link  |  Quote  |  Print  |  Notify Moderator
352 wrote:
Is your name Robin Williams? RV RV RV
he didn't hold the Y coupler up high enough!
