RV.Net Open Roads Forum: Travel Trailers: Black Water Accident
 > Black Water Accident
Page of 5
kellem
Shenandoah valley,VA
Posted: 07/03/20 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
I have a black tank rinser on latest trailer but have yet to use it.
Never had it on previous trailers and never needed it.
Indeed a great concept but keeping black tank wet works marvelously.
Bobbo
Wherever I park
Posted: 07/04/20 06:51am Link  |  Quote  |  Print  |  Notify Moderator
Never having used it, you have no way to know if you ever needed it. I use a clear section between my stinky slinky and the RV so I can see "stuff" coming out of the tank. Just pulling the handle lets it flow freely. When the flow stops, I turn on the tank rinse. I always get more solids out. Not a lot, but enough. If I had never done that, I would have thought that I never needed it either.
Bobbo and Lin
GrandpaKip
Flat Rock
Posted: 07/04/20 07:56am Link  |  Quote  |  Print  |  Notify Moderator
Ditto on the clear extension.
It is amazing how much more stuff comes out with a rinse. And I always have a wet tank, also.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
jpmyers
Posted: 07/04/20 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
Great idea Bobbo! I have the clear 90s on both of my tank outlets and have another for the exit end of my hose. I would like to find a clear Y but the opaque I have is sufficient.
I use the built in BWT flush nearly every time I dump my BWT. As Bobbo described, I open a dedicated hose to the flush after dumping had become a small trickle. My difference is that I'll close off the BWT valve and let the flush run for 3 minutes, then open. I'll do that for an many cycles as it takes to get a clear, "chunk-free" stream.
I am looking to put more clear pieces into my system. Anything that gives me a better indication of having properly cleaned my tanks, to me, is worth the time, effort and expense.
That said, anyone know if a good resource for RV plumbing supplies?
Jerry & Pamela
2020 Highland Ridge Silverstar ST324RLS-38' Tag-A-Long
2020 1500 w/Max Haul package & Airlift air bags.
CavemanCharlie
Storden,MN
Posted: 07/05/20 11:42am Link  |  Quote  |  Print  |  Notify Moderator
So what if a little "Stuff" stays in your black tank . As long as you keep a little water in the tank to keep it moist the "Stuff" will come out the next time you dump. I never try to get mine perfectly clean and I've had this, made in 1993, TT for 10 years now.
Turtle n Peeps
California
Posted: 07/05/20 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
LOL, I never did get the perfectly clean black tank either?
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
Lynnmor
Red Lion
Posted: 07/05/20 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
If you store the trailer in a garage, it sure is nice to have all the stuff out of the tank.
Mickeyfan0805
SE Wisconsin
Posted: 07/06/20 09:52am Link  |  Quote  |  Print  |  Notify Moderator
pmlevine wrote:
Well, there is a waste drain at each campsite, so no, I am not making other folks wait while I try to jet rinse the black tank. This model TT came equipped with a built-in jet rinse for the black tank. There is a separate, dedicated hose port on the TT specifically for the jet rinse. I only use the jet rinse after first draining the black tank, then the grey tank. The jet rinse is done with only the black valve open, and is the last thing I do before leaving the campsite.
So I also don’t understand why BurpMan does not like the idea of hooking up a hose from the campsite water supply to the separate jet rinse port on the TT.
I do the same thing. Empty tanks...flush black tank using the rinse port...close valve and let run for a minute to put a few gallons of fresh water into the tank so it doesn't run dry. Simple and certainly no risk to the water system of the campground.
jpmyers
Posted: 08/01/20 10:20am Link  |  Quote  |  Print  |  Notify Moderator
Well I've got a good one. I was flushing my BWT. I normally stay with it and will close the black water valve for no more than 3 minutes for the tank flush to do it's thing. However, on the 5th flush, I got to "multi-taking." The next thing I know, water is pouring down the sides of my RV. I can't imagine how bad this would have been had it occurred during the 1st flush! This rig is less than a month old. From what I can tell, nothing penetrated into the walls as the crevice seals seen to have done their job.
kellem
Posted: 08/01/20 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
Trying to get my head around this and sorry but had to laugh.
You saying you filled the black water tank above capacity and it ran out the roof vent and down the sides of trailer ?
Say it isn't so.
Page of 5
