RV.Net Open Roads Forum: Fifth-Wheels: Adding on board Generator
 > Adding on board Generator
roachcoach
Kern County California
Posted: 06/30/20 03:04pm Link  |  Quote  |  Print  |  Notify Moderator
Looking for advice on type of on board generator to purchase.
Want to run 2 15k ac, 2 tvs and satellite. Also do most generators have fuel tank or just add tank?
I have a Champion 3100 that I have been using but want something bigger and more quiet. Looking for someone who has a onboard generator.
Thank you
Paparoach48
Richard & Rachel
2006 Damon Astoria Diesel Pusher
2004 Jeep Liberty
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 06/30/20 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
We have an OEM Onan 5.5 Propane Generator in our unit. Most factory installed Gennys in Trailers are Propane powered because of the lack of a place for a fuel tank, unless you have a ToyHauler that has it's own fuel station.
We can run almost every thing in our unit, but under full load it burns through approx a gallon of Propane per hour, so it will empty a 40 tank in approx 8 to 10 hours.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
PhilipB
MO
Posted: 06/30/20 03:45pm Link  |  Quote  |  Print  |  Notify Moderator
We have the same 5.5 Onan that Michelle.S has, but gas version. Will run both A/C's plus frig, tv, etc. We have a toyhauler so we have 60 gal. of fuel capacity onboard
I think you'd want a diesel 6 or 8K unit based on your rig. It should be plumbed into your onboard engine tank.
2015 Ram 2500
2013 Raptor 310TS
bobsallyh
Livingston, TX.
Posted: 06/30/20 04:12pm Link  |  Quote  |  Print  |  Notify Moderator
You only have about 2 choices for an onboard genny, Onan or Generac. A number of years ago, Honda made an onboard RV genny. It was water cooled and never really got established in the RV market onboard picture. If Honda would bring out a genny to match the size, etc. of aforementioned gennys, those two would be out to pasture. I have an Onan Marquis Gold 7000 gas in our fiver. It will pull two AC's, hot water heater and numerous other things. But one thing to remember is an Onan is like an old woman, needs a lot of TLC.
KD4UPL
Swoope, VA
Posted: 06/30/20 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
Since you have a diesel rig you need to get a diesel generator. Cummins/Onan is the brand you want. Stay away from Generac. Those are basically the only two choices.
NRALIFR
Truck Camping Out West
Posted: 06/30/20 07:36pm Link  |  Quote  |  Print  |  Notify Moderator
Actually, Generac no longer makes built-in RV generators either. They make some dandy mobile (towable) gensets, however! [emoticon]
Your only choice is Cummins Onan.
[emoticon][emoticon]
2001 Lance 1121 on a 2016 F450
Bionic Man
Colorado
Posted: 06/30/20 10:55pm Link  |  Quote  |  Print  |  Notify Moderator
Are you asking for the pusher that is in your signature and photo, or a 5er, like the forum you posted?
On my 5er, I have one of the built in Honda's. I'm happy with it, but it does burn a lot of propane. I had it installed way back when we bought the trailer in 2002. Only 200 hours on it. When I bought, there was an option to somehow use an outboard boat motor fuel tank. That would have given me longer range and maybe easier to fill, but then you have to worry about the carbs when the generator isn't used often. I guess propane was the right way to go.......
2012 RAM 3500 Laramie Longhorn DRW CC 4x4 Max Tow, Cummins HO, 60 gallon RDS aux fuel tank, Reese 18k Elite hitch
2003 Dodge Ram 3500 QC SB 4x4 Cummins HO NV5600 with Smarty JR, Jacobs EB (sold)
2002 Gulf Stream Sea Hawk 29FRB with Honda EV6010
pianotuna
Regina, SK, Canada
Posted: 06/30/20 11:29pm Link  |  Quote  |  Print  |  Notify Moderator
Part of the noise is you are pushing the 3100 extremely hard. I'm surprized it will run two roof air units at the same time.
Yamaha makes a 4500 watt, and Honda a 6000 watt inverter generator. See if you can go listen to them at a dealership--and plug in your RV as a test.
You may wish to investigate a sound baffle box around any generator.
A totally quiet alternative would be a large solar farm with a BIG battery bank.
Regards, Don
roachcoach
Posted: 07/01/20 09:17am Link  |  Quote  |  Print  |  Notify Moderator
Sorry about the picture need to change it as I no longer have a motorhome (Totaled out)
Now own 2013 fifth wheel Heartland landmark.
pianotuna
Regina, SK, Canada
Posted: 07/01/20 09:44am Link  |  Quote  |  Print  |  Notify Moderator
Don't go to a propane generator. You may be visiting the propane supplier every day if you do.
