RV.Net Open Roads Forum: Onan Generator Start Motor Continues to Run
 > Onan Generator Start Motor Continues to Run
whemme
Spencer, IA
Posted: 06/30/20 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
Interesting problem. I have a 2002 Class-C with an Onan Emerald BGE 4000 watt generator. For some reason when I push the start button on the generator that after the generator starts the starter motor continues to run. Only way to stop that is to push the stop button which of course also shuts off the generator. Anyone else experience this problem and what the fix it?
2002 Born Free 26' RSB Motorcoach
2005 Chevrolet Malibu LS Toad
Home Skillet
Pearland Texas
Posted: 06/30/20 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
The starter bendix or solenoid,
may be sticking.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
whemme
Spencer, IA
Posted: 06/30/20 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
But pressing the stop switch would not change a stuck solenoid or bendix.
bobndot
Posted: 07/01/20 05:50am Link  |  Quote  |  Print  |  Notify Moderator
Maybe this might help you ? The Onan might be set up the same way. I guess its worth a look. See the pic and explanation below it.
diagram for testing a generator starter
Dusty R
Charlotte Michigan 48813
Posted: 07/01/20 07:00am Link  |  Quote  |  Print  |  Notify Moderator
Do you also have a start-stop switch in side your mh? If so does that inside switch O.K. ?
