RV.Net Open Roads Forum: Black Tank Roof Vent and Bathroom Roof Vent Too Close?
 > Black Tank Roof Vent and Bathroom Roof Vent Too Close?
BFL13
Victoria, BC
Posted: 06/30/20 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
In the TC (see sig) there can be a whiff of tank smell that apparently comes from the open roof vent by way of the tank vent nearby, but not positive that is the source. It is not coming from the toilet or from where the toilet is sealed to the flange, which has been renewed.
Is there a trick to this, like make the tank vent higher or a different sort of cap on it? Of course we can keep the bathroom roof vent closed except when necessary, but like it open in hot summer weather.
Thanks.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
enblethen
Moses Lake, WA
Posted: 06/30/20 08:17pm Link  |  Quote  |  Print  |  Notify Moderator
I would install one of these.
Vent hood
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
BFL13
Victoria, BC
Posted: 06/30/20 08:46pm Link  |  Quote  |  Print  |  Notify Moderator
The vent hood could help, thanks. Not one there now. The hood opening facing forward is away from the tank vent in back. The vent now does not have a fan, which is unusual, but there is a bathroom window that opens. I guess the idea to clear the air is open the window and the roof vent. Kind of silly in February!
I will get the whole deal new with the fan and the vent hood next project. BTDT with a previous RV. I can steal 12v for the fan from the ceiling lamp.
opnspaces
San Diego Ca
Posted: 06/30/20 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
If there is a sink close to the toilet poke your head into the cabinet and take a whiff. It's possible the smell is coming from there and not off the roof. If that's where the smell comes from you can unscrew and replace the air admittance valve.
Link
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
enblethen
Moses Lake, WA
Posted: 06/30/20 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
Opening, high end of the vent hood should face toward the rear. We leave our vent lids open a couple inches to get natural ventilation. This reduces or eliminates negative pressure inside the rig that can suck fumes of many types in.
BFL13
Victoria, BC
Posted: 06/30/20 09:52pm Link  |  Quote  |  Print  |  Notify Moderator
You are right that the opening should be to the rear so the vent lid can be raised. But that is right where the tank roof vent is. If I go all new maybe I can put it in backwards so the opening is forward. Not the right way for vortex and all that, as mentioned. Hmmmm.
I think the vents open pointing aft so the lid won't blow off if you leave it open a bit while driving. With the vent hood on, that lid should be safe from blowing off.
Good point about the sink. There is no grey water tank in the TC, it shares with the black when not on hook ups. (No hook-ups you can simply have the grey pour into a bucket and put a lid on that to dump the bucket somewhere later, if not suitable to let it drain out with a hose off to the side.)
There is also a shower drain in the floor in front of the toilet. The TC has a sort of "wet bathroom".
We don't use the blue stuff, which smells bad IMO. We just use soap down the toilet and that works in our other Rvs no problem. Just have to get this one in shape too.
Good ideas, thanks.
ndrorder
Southwest
Posted: 07/01/20 06:41am Link  |  Quote  |  Print  |  Notify Moderator
No harm in routing the vent horizontal across the roof as long as it is well secured during travel.
__________________________________________________
Cliff
2011 Four Winds Chateau 23U
BB_TX
McKinney, Texas
Posted: 07/01/20 09:40am Link  |  Quote  |  Print  |  Notify Moderator
Unfortunately, a common layout since both are typically right about the toilet.
And every time you flush, the sudden drop of water into the black tank will push that volume of air out the vent. And if the wind direction is blowing from the tank vent to the open bathroom vent, in it goes. A new vent with a fan might solve the problem, but would require wiring in the electric.
enblethen
Moses Lake, WA
Posted: 07/01/20 09:57am Link  |  Quote  |  Print  |  Notify Moderator
Check under the galley sink for air admittance valve
MrWizard
Traveling
Posted: 07/01/20 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
"I think the vents open pointing aft so the lid won't blow off if you leave it open a bit while driving. With the vent hood on, that lid should be safe from blowing off."
If the vent lid is open when driving
You will have a ram air scoop into the bathroom
Radiate The Happy
1997 F53 Bounder 36s
