RV.Net Open Roads Forum: Toy Haulers: Power issue
Search only in Toy Haulers
 > Power issue
abc40kids
Dale City,Virginia
Posted: 07/01/20 06:43pm Link  |  Quote  |  Print  |  Notify Moderator
Friend called and is camping and his ac not coming on also some lights not working and the ones that are, are dim?? Converter or battery?? I’m told his battery’s are almost dead. Thanks!! It’s a heartland toyhauler
Jeff,Julie,Amber,Brandon,and Casey and Winston ( our 5 year old Golden ) and Bruno the Pug. We now have an English Cream, white Golden Retriever as well.
2015 Keystone Montana Mountaineer 356TBF
2005 Chevy duramax dually
Mono Basin National Forest Scenic Area
Posted: 07/01/20 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
RV batteries won’t and don’t run an A/C.
LowRyter
OKC
Posted: 07/01/20 08:47pm Link  |  Quote  |  Print  |  Notify Moderator
Battery won't run the air.
John L
WW SL 2805 5th Wheel
2004.5 Chevy 2500HD Allison Duramax X Cab
Moto Guzzi V11 Sport, Moto Guzzi EV California and Suzuki 1200 Bandit
Y-Guy
Tri-Cities, WA
Posted: 07/01/20 10:08pm Link  |  Quote  |  Print  |  Notify Moderator
Needs to fire up the generator and charge things up. If his batteries are to low to fire up the generator he needs to hook up the power cable for lights/brakes to the truck and fire it up. That should give him enough power to get the generator running.
If he's using an inverter to take power from the 12v batteries he could be draining his batteries. Without knowing his battery setup it's hard to say, and not knowing how well he maintains the batteries or their age it's hard to give much advice.
2007 Winnebago Sightseer 35J
2011 Jeep Wrangler
schlep1967
Harrisburg, PA
Posted: 07/02/20 10:54am Link  |  Quote  |  Print  |  Notify Moderator
So many questions.
1.Is he hooked up to shore power? Is the breaker on?
2. If yes to the above, did he check all of his breakers on the panel? Converter is generally plugged into the back of the panel and won't charge batteries without A/C power.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
 > Power issue
