RV.Net Open Roads Forum: Anyone pull with a 2020 GMC 2500 standard box?
Search only in Toy Haulers
 > Anyone pull with a 2020 GMC 2500 standard box?
Raptormom02
Corona, CA
Posted: 07/01/20 11:21pm Link  |  Quote  |  Print  |  Notify Moderator
Looking at getting a 2020 GMC 2500 standard box and I was wondering what kind of hitch people are using? We love our superglide but what other self gliding hitches are there?
corvettekent
Marysville, WA
Posted: 07/02/20 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
I know people do but I would never pull a 5th wheel trailer with a short box truck. A long box truck will pull better, back better, and has a larger fuel tank.
2007.5 GMC Dually EC/LB, LMM. Banks IQ, Speed Brake, Six Gun. B&W Turnover Ball, Companion Hitch, Amp power steps. Hadley Air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
nayther
Burbank, CA
Posted: 07/02/20 04:46pm Link  |  Quote  |  Print  |  Notify Moderator
I woldn't own a long bed or a dually, too big of a truck for everyday. Plus longer truck means wider turning radius for backing into tight spots. Just my opinion. I'll be replacing my 2016 Duramax with a 2021 in the fall. Crew cab "standard" bed is my preference.
The new trailers have much more rounded corners and offset pin boxes that I've only used my sliding hitch twice since 2006, once didn't even need to but wanted to try it.
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
Thermoguy
Graham, WA
Posted: 07/02/20 06:30pm Link  |  Quote  |  Print  |  Notify Moderator
Since you posted in the Toy Hauler section, if your getting a new truck, why not a 3500? If I could replace my 2500 right now, it would be a 3500. I've looked at lots of trailers that are just too heavy for a 2500. Toy Haulers tend to be out of spec for a 2500.
As for your slider question, I don't have a slider for my 5th wheel hitch. Have to be careful when backing, but doesn't effect me when driving forward.
Raptormom02
Corona, CA
Posted: 07/03/20 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
We pull with a 2002 2500HD right now and it pulls our TH fine, just looking to upgrade to a new truck. We live in CA and the registration on a 2500 is expensive and the 3500 is even more. The small tow difference between the 2500 and 3500 (2800lbs) on the Chevy/GMC probably wont even be noticed. Our TH is 10500 so either would work.
We have a supreglide hitch for our 2002 and love it. Just wondering what options are available that have automatic slides for the 2020 GMC/Chevy.
nayther
Burbank, CA
Posted: 07/06/20 11:00am Link  |  Quote  |  Print  |  Notify Moderator
If you're 2002 tows your current trailer fine you'll be totally blown away with a new one, TONS more power and the transmissions are now 10 speeds and reportedly very reliable (my mechanic said they "split" the gears). My first Duramax was a 2005, then 2012 to 2013 (lemoned the 2012). LOVE my 2013 but it will be replaced with a 2021 soon. The inventory in So Cal for 2020's is very poor right now.
ugeesta
Denver
Posted: 07/07/20 05:54am Link  |  Quote  |  Print  |  Notify Moderator
The need of a slider hitch depends on the location of the pin and the width of the trailer.
We towed a Puma Unleashed toy hauler with a standard bed 2002 GMC for several years and worked just fine. The trailer was 96” wide and the pin was slightly forward of the trailer cap. Never had to use the slider.
Our current trailer (Jayco Talon) is 102” wide and the pin is under the cap. Now if I need to do an extreme angles backing maneuver, I need to extend the slider.
Check those two trailer conditions to see if a slider hitch is necessary. We have a B&W Companion. Heavy as hell but a nice hitch. Don’t know about any other hitches.
2018 GMC Seirra 3500 Denali SRW
2018 Jayco Talon 313t
2019 Polaris XP1000 Trail and Rocks edition
2016 Yamaha Grizzly EPS
1 wife & 5 cats
N-Trouble
NorCal
Posted: 07/07/20 08:45am Link  |  Quote  |  Print  |  Notify Moderator
False, false, false... Nothing but “old school” thought here.
2015 Attitude 28SAG w/slide
2012 GMC 2500HD SLT Duramax
B&W Turnover w/Andersen Ultimate 5er hitch
dedmiston
So Cal
Posted: 07/07/20 08:58am Link  |  Quote  |  Print  |  Notify Moderator
I don't know about that. [emoticon]
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
nayther
Burbank, CA
Posted: 07/08/20 10:29am Link  |  Quote  |  Print  |  Notify Moderator
yea, you have the monster truck. But you commute via Metrolink correct? My truck is my company truck, need to park in parking garages and surface lots in downtown L.A. at times, or squeeze into tight spots at Space X. Even single wheel long bed won't cut it.
