RV.Net Open Roads Forum: Class A Motorhomes: Disappointing test drive
 > Disappointing test drive
A1ARealtorRick
Gulf Shores, AL
Posted: 07/02/20 11:38am Link  |  Quote  |  Print  |  Notify Moderator
My wife and I are shopping for a new gas Class A. We drove a 2020 Winnebago Sunstar yesterday, and, from a driver's standpoint, it was quite a disappointment.
Bearing in mind that our last Class A was a 2003 Winnebago Journey DP with a 5.9-liter 300hp Cummins, I had expected the engine noise level to be a good bit higher -- it naturally was, but not as bad as I had anticipated.
The real disappointment was that I had to continually correct the steering to keep the rig in the lane, minor corrections, but still irritatingly continual. Also, I felt every little bump in the road through the steering wheel, and the bulk of the test drive was on a 4-lane divided highway. By the time we returned from the drive my fingers were actually a little tingly.
Please tell me all Class A gassers do not drive like this. It was our first test drive this time around, and I'm hoping subsequent test drives in other makes don't end up feeling the same way.
. . . never confuse education with intelligence
rgatijnet1
Posted: 07/02/20 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
Hard to tell how any coach rides and drives when it is empty. Loaded for travel the suspension will not be as stiff and if loaded properly it may not wander going down the highway. The tire pressures may have been too high or too low or uneven from it sitting on the lot. This can also affect the ride/handling.
way2roll
Wilmington NC
Posted: 07/02/20 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
The 2 I had certainly drove like that. The 2021 Ford chassis may help some of that but Gas Class A's on the F53 are notorious for harsh ride, noise and road feedback. That's why our new rig will likely be a DP or a truck and FW. For long trips I just can't handle anymore being stressed out or beaten to death by the time I get to my destination.
2020 FR Cedar Ridge Silverback 29rw
dodge guy
Bartlett IL
Posted: 07/02/20 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
My 12 was like that when I bought it last year. It was all over the road. Didn’t notice it on the test drive around the dealer. But bringing it home it was a miserable drive. I have to do constant corrections. The previous owner added all that was available for the F53 chassis. What I found was the tire pressure were all at 110psi. And then I found the front tires were toed out 5/8”. I did a tape measure adjustment and set it to 3/16” toe in. Now the MH drives like my previous Ford Excursikn and 35ft TT. Sometimes it’s the simple things that makes the biggest improvement.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
dougrainer
Carrolton, Texas
Posted: 07/02/20 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
If that was a Ford Chassis, the thing about Ford Chassis is, They have to be aligned CORRECTLY. When you have a Ford aligned correctly, they handle like a dream. I would test drive other Class A 2020 Fords and I will bet you will find out that you had a bum Ford that needed an Alignment. Did you give that feedback to the Dealer you test drove from? Doug
John Wayne
Long Beach, Ca
Posted: 07/02/20 02:17pm Link  |  Quote  |  Print  |  Notify Moderator
Not that it would make a difference but if you want to get the new V8 make sure your purchase is on the new V8 chassis, and not the older v-10.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
mikestock
Vestavia Hills, AL, USA
Posted: 07/02/20 02:25pm Link  |  Quote  |  Print  |  Notify Moderator
After driving my used Tiffin Phaeton for a year and dealing with the all-over-the-road problem I added a Roadmaster stabilizer and found that it made a world of difference. I only do about half the steering I did before and am not pushed all over the road by bumps and road imperfections. My MH is a diesel pusher and I can say the problem is not unique to gas models. Most of the high end motor homes today come with a stabilizer system.
doxiemom11
Paris Michigan
Posted: 07/02/20 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
We have an older F53 and the cheap handling fix along with a steering stabalizer made a world of difference. Don't know if the fix can be done on newer ones or not. There was also a big difference between unloaded and loaded.
azdryheat
Tucson, AZ
Posted: 07/02/20 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
When I'm moving coaches between dealerships I find them all to be rough riding and steering's a little squirrely. Mostly this is from sitting on the lot and not being driven. Once I get 30 or so miles on them the tires settle down and steer normally. Take a longer test drive.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2011 Harley Ultra Limited
2016 RZR 900
garyemunson
Reno, Nevada
Posted: 07/02/20 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
X2 on what Doug said. F53 chassis drive best when toe in is set to the max value of .14+. This will result in faster wear on the outer edges of the front tires but almost all of us replace tire due to age, not wear. My 36Y Vista goes down the road like an arrow. As Doxiemom says, the CHP is also a help. Still doable on F53 chassis.
The new V8 chassis comes with much bigger sway bars and would not need it.
