RV.Net Open Roads Forum: Onan Marquis 5500 put out too much voltage
 > Onan Marquis 5500 put out too much voltage
SuzanneNS
calgary
Posted: 07/02/20 11:39am Link  |  Quote  |  Print  |  Notify Moderator
We bought our motorhome used and not running!!! My husband is a great mechanic and got it running. He had to clean the fuel tank, put in a new fuel pump and it fired right up...we got lucky! The previous owner had fiddled with the Onan generator and we were given a box of parts he hadn't reinstalled. My husband rebuilt the engine and it runs great but puts out too much voltage. He contacted a company called Flight Systems and run a bunch of diagnostics to determine what was wrong. They sold us a new voltage regulator. He installed it but it got fried....so they sent us another one but generator is still putting out too much voltage. When we fire it up, it puts out about 200 volts and settles to 170. He hasn't connected to the motorhome until he gets this figured out. Any suggestions would be so appreciated!
2oldman
Mecca
Posted: 07/02/20 11:42am Link  |  Quote  |  Print  |  Notify Moderator
Lots of hits on that on google. Perhaps it's running too fast.
Lone Pine, CA
Posted: 07/02/20 11:49am Link  |  Quote  |  Print  |  Notify Moderator
"He hasn't connected to the motorhome until he gets this figured out."
And be very sure it is fixed before you do.
bgum
South Louisiana
Posted: 07/02/20 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
Old man has the answer for the first thing to check.
SuzanneNS
calgary
Posted: 07/02/20 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
thanks! I will let my husband know to check that
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 07/02/20 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
The motor would have to be screaming fast to put out that voltage
Dusty R
Charlotte Michigan 48813
Posted: 07/02/20 07:17pm Link  |  Quote  |  Print  |  Notify Moderator
Check the RPM the engine is putting out and find out how many RPM it's rated at.
STBRetired
I-80 and I-55
Posted: 07/02/20 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
The engine is supposed to be running at 1800 RPM. Look at the rating plate on the right side.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
MrWizard
Traveling
Posted: 07/02/20 11:35pm Link  |  Quote  |  Print  |  Notify Moderator
Get the model #
From the data plate on the onan
Download the service manual
All of these older generators are capable of putting out 230v, it depends on how the 4 output wires from the stator (out put windings) are connected,
At 200v , it is probably connected for 230 but running too slow to produce full voltage
Flight system control boards are the best there is
Radiate The Happy
1997 F53 Bounder 36s
Kpackpackkelley
Bryan tx
Posted: 07/03/20 07:13am Link  |  Quote  |  Print  |  Notify Moderator
Need the full model number
