RV.Net Open Roads Forum: Travel Trailers: Melting wires
 > Melting wires
pianotuna
Regina, SK, Canada
Posted: 07/04/20 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
GrandpaKip wrote:
I think you are fortunate to have come out of this relatively unscathed.
Having to possibly replace a 30 day old air conditioner is not what I'd call unscathed.
I agree he is lucky the RV did not burn down.
Regards, Don
philh
Belleville MI
Posted: 07/05/20 07:02am Link  |  Quote  |  Print  |  Notify Moderator
I replaced my charger converter and discovered the inbound AC hot wire was never tightened. I know RV's are slammed together cheaply, but WTH, you shove the wire in and forget to tighten the screw???
LVJJJ
NW WASHINGTON
Posted: 07/05/20 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
I've found many a loose ground wire over the many years and many trailers behind me. Probably the most important wire of the whole bunch.
1994 GMC Suburban K1500
2005 Trail Cruiser TC26QBC
1965 CHEVY VAN, 292 "Big Block 6" (will still tow)
2008 HHR
L(Larry)V(Vicki)J(Jennifer)J(Jesse)J(Jason)
kearlms
Rexburg, ID
Posted: 07/05/20 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
I agree on the loose wires. I go through all the wires at the panel in my TT at the beginning of the year and tighten them just to make sure this does not happen. Might be a good practice for your preventative maintenance check list each year. Sorry to hear this has happened.
Lynnmor
Red Lion
Posted: 07/05/20 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
Everyone loves those detachable cords, (I hate them) but how many check the tightness of the wires behind the inlet? My guess is that nearly all are never checked and that is a connection within the Styrofoam and thin plywood walls. My inlet fell to the ground when I removed it, all screws were completely loose.
CharlesinGA
South of Atlanta, Georgia
Posted: 07/05/20 08:41pm Link  |  Quote  |  Print  |  Notify Moderator
I have converted two different trailers to the twist lock cord connector. One was the stupid mouse hole, and the other had a door and a small compartment you were expected to wad the cord up and stuff it into.
Now, I did the work myself and the connections on the back of the inlet and at the panel (and transfer switch on the last one) are all doubly tight. And I check them every year or so depending on usage. Every terminal, wire nut and connection in both the 12vdc and the 120vac system should be checked every year or more depending on how much the trailer or motor home gets used. Its all about rattling along down the road that loosens stuff up.
Charles
'03 Ram 2500 CTD, 5.9HO six speed std cab long bed Leer top and 2008 Bigfoot 25B21RB.. previously 2008 Thor/Dutchman Freedom Spirit 180. SOLD - 2007 Winnebago View 23H Motorhome.
 > Melting wires
