RV.Net Open Roads Forum: Class A Motorhomes: Roof Caulk Question
 > Roof Caulk Question
stugpanzer
Illinois
Posted: 07/05/20 09:02pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2006 Fleetwood Pace Arrow. The caulk on the roof looks to be in good shape but there appears to be silicone caulk around the edges where the roof meets the sides with a trim piece and that is no longer 'sticking' to the roof. Does anyone know is that just a matter of pulling the old silicone caulk off, clean the area then re-apply? I have no leaks (that I can find) but those edges concern me.
2006 Fleetwood Pace Arrow 37C
Mods: EEZRV Products TPMS, Cobra 29LX 50th Anniversary CB radio with Firestik NGP Antenna, Self contained sewer hose
craig7h
Branson MO area
Posted: 07/06/20 02:54am Link  |  Quote  |  Print  |  Notify Moderator
I would say basically you are correct. However its not just the average sealer used. For the roof I have used the dicor self leveling product. For the side application I use Sikaflex Sealant for RVs, its a great product.
Itasca Meridian SE 36g
Road Master Tow Dolly
garyemunson
Reno, Nevada
Posted: 07/06/20 05:29am Link  |  Quote  |  Print  |  Notify Moderator
Anytime you have a trim piece (or window frame) that "squishes" a sealer down, the correct repair involves removing the trim/frame and replacing the butyl sealer tape underneath it. 10 more years of trouble free sealing. It comes in different widths so measure. You will often need to build the screw holes back up with carpenter's glue and toothpicks.
https://www.amazon.com/Dicor-BT-1834-1-Butyl-Seal-Tape/dp/B001FCB4JS/ref=sr_1_3?crid=SIFGQTQY9ZVF&dchild=1&keywords=butyl+tape+rv&qid=1594034925&sprefix=butyl%2Caps%2C229&sr=8-3
Sjm9911
New Jersey
Posted: 07/06/20 08:08am Link  |  Quote  |  Print  |  Notify Moderator
Just make sure you clean the silicon off, nothing sticks to silicon, including silicon. And what they said!
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
stugpanzer
Illinois
Posted: 07/06/20 09:06am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, everyone! I will be tackling this project very soon!
schlep1967
Harrisburg, PA
Posted: 07/06/20 09:55am Link  |  Quote  |  Print  |  Notify Moderator
FYI. What you have may not be silicone. Dicor makes a Non-sag sealant for vertical applications. Either way clean it well before new application.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
way2roll
Wilmington NC
Posted: 07/06/20 10:26am Link  |  Quote  |  Print  |  Notify Moderator
Examining the roof and seams is something that should be done at least once a year if not twice. I'm a little OCD so admittedly I was on my roof about every month. [emoticon]
352
Oxfofd, Fl
Posted: 07/14/20 01:25pm Link  |  Quote  |  Print  |  Notify Moderator
DO NOT RE CAULK WITH SILICON OR YOU WILL DO IT EVERY YEAR
The manatees of Halls river Homosassa Springs Fl
1985 Chevy Silverado c10. 454 stroker / 495 CI = 675 HP. 650lb of torque. Turb0 400 tranny. 3000 stall converter. Aluminum heads. 3 inch exhaust flowmasters. 2 inch headers. Heat and air. Tubed.
352
Oxfofd, Fl
Posted: 07/16/20 02:39pm Link  |  Quote  |  Print  |  Notify Moderator
HERE
