RV.Net Open Roads Forum: Tech Issues: Tapping off of the 3/8 Propane Line
 > Tapping off of the 3/8 Propane Line
datedd1
Oak Hills
Posted: 07/06/20 11:13am Link  |  Quote  |  Print  |  Notify Moderator
I installed a residential refrigerator and capped off the existing 3/8" propane line that once ran to the Dometic. I would like to exploit that line by using it as a propane source for my gas grill so that I don't have to carry canisters or run a long hose underneath the coach from the TEE on the propane tank. I am having a hard time figuring out the fitting and hose combination to tap off that line. (pictured)
Once again, it's the 3/8" female flare with a 3/8" male flare cap on it.
Any suggestions would be appreciated.
Sjm9911
New Jersey
Posted: 07/06/20 11:23am Link  |  Quote  |  Print  |  Notify Moderator
Not sure on the conection, but if the line is low pressure it may not work well depending on you stove/grill hook ups. If you ran it off of a propane tank then you need high pressure, or un regulated LP gas flow. I think the fridge is low pressure lp gas flow, so you will be double regulating the appliance.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Bipeflier
Centralia, MO
Posted: 07/06/20 01:47pm Link  |  Quote  |  Print  |  Notify Moderator
Most external ports for propane are after the regulator. Whatever you hook to can not have an additional regulator.
Any hardware store will have what you need to extend the line. You may have to order a quick coupler to suit your grill.
2010 Cruiser CF30SK Patriot
2016 3500 Duramax
1950 Right Hand Seat GPS (she tells me where to go)
corvettekent
Marysville, WA
Posted: 07/06/20 05:50pm Link  |  Quote  |  Print  |  Notify Moderator
That propane line will work but it is after the regalator so you will need to remove the regulator from the BBQ.
2007.5 GMC Dually EC/LB, LMM. Banks IQ, Speed Brake, Six Gun. B&W Turnover Ball, Companion Hitch, Amp power steps. Hadley Air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
Sjm9911
New Jersey
Posted: 07/06/20 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
We need to see what they have for a grill/stove, some have the regulator built into the unit and can not be removed. Others can be adapted.
philh
Belleville MI
Posted: 07/06/20 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
I've never found one that couldn't be removed [emoticon]
For my camp stove, I set up two different hoses, both on quick disconnects. One is for 20lb tanks, the other is for pressure reduced trailer propane.
Little POS grill, took a bit more work, as it was designed to work with 1lb propane canisters... but it's also now plumbed with quick disconnects for trailer.
red31
Dallas
Posted: 07/06/20 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
https://www.mbsturgis.com/
MEXICOWANDERER
las peñas, michoacan, mexico
Posted: 07/06/20 07:45pm Link  |  Quote  |  Print  |  Notify Moderator
First things first...
Immediately after a "T" tap comes an LPG rated shut off **** valve. Then fittings for an LPG rated hose. There are quick connect low pressure disconnect fittings
So you van swivel the valve shut the quick disconnect and roll up the hose.
Sjm9911
New Jersey
Posted: 07/06/20 07:52pm Link  |  Quote  |  Print  |  Notify Moderator
Dwpends on the stove / grill/ griddle. This is a common topic on the pop up boards, less inside area to cook with. Dosen't help that most dont know high from low pressure set ups. And that quick connects are not for high pressure conections, they can work but are not legal. I couldent get a line made for my high pressure conection, even from a place that custom made lines. And the diffrent connections. I hated low pressure stuff. I carry a separate 20 lb tank and hook up to that. Most of my propane is burned for cooking anyway. Easier.
Retired JSO
North Georgia Mountains
Posted: 07/06/20 08:59pm Link  |  Quote  |  Print  |  Notify Moderator
Should work. We used to supply a 40,000 btu space heater off 3/8” copper tubing.
