RV.Net Open Roads Forum: Truck Campers: Propane Generator to Gas.
 > Propane Generator to Gas.
Ranger Tim
Idaho
Posted: 07/06/20 11:25pm Link  |  Quote  |  Print  |  Notify Moderator
Just when I was thinking of converting my Honda to run on Propane!
Ranger Tim
2006 F-350 Super Crew King Ranch SRW Bulletproofed
2016 Wolf Creek 840
Upper and Lower StableLoads
dirtyhandz
ohio
Posted: 07/07/20 06:24am Link  |  Quote  |  Print  |  Notify Moderator
Removing 1 of 7.5 gallons propane cylinders make plenty of storage for gas can.... with triple running time.
This is the main reason the thought entered my head. I end up carrying my Honda 2000's and a can of gas because the on board eats so much propane and getting tanks filled can be difficult sometimes.
midnightsadie
ohio
Posted: 07/07/20 07:21am Link  |  Quote  |  Print  |  Notify Moderator
worry about fuel use? install a diesel gen set. I have a pp and love it. its now 13yrs old and fires right up.
mkirsch
Rochester, NY
Posted: 07/07/20 07:33am Link  |  Quote  |  Print  |  Notify Moderator
It's easy. Remove the propane regulator, evaporator, and carburetor, then install a gasoline carburetor. The challenge is in finding the right gasoline carburetor for the engine especially if it's computer controlled. Maybe Onan makes one that you can get from an Onan dealer through their parts department.
towpro
Compass PA
Posted: 07/07/20 07:37am Link  |  Quote  |  Print  |  Notify Moderator
Kayteg1 wrote:
jimh425 wrote:
The reason why small RVs don’t have gasoline engine generators is they don’t typically have gasoline storage built in.
well maybe 30% longer, but not 300% longer. But Propane is a whole lot safer.
conventional gasoline has an energy content of 116,090 Btus per gallon, while propane has an energy content of 84,250 Btus per gallon. As such, 1.38 gallons of propane has the same amount of energy as one gallon of conventional gasoline.
Forest River Forester 2401R Mercedes Benz.
Sold: 2016 Arctic Fox 990, 2018 Ram 3500, 2011 Open Range
Kayteg1
California > Nevada
Posted: 07/07/20 08:52am Link  |  Quote  |  Print  |  Notify Moderator
For years, as a joke on other forum I added "seeking diesel push mower" into my profile.
Took 5 years and fellow member found me 1, but at $7000 price tag, I passed.
AnEv942
CA
Posted: 07/08/20 09:39am Link  |  Quote  |  Print  |  Notify Moderator
Our Generac impact-36 rated fuel usage
FUEL CONSUMPTION (IN GALLONS PER HOUR):
LOAD - GASOLINE - LP
NO ------ 0.14 --------- 0.20
HALF --- 0.32 --------- 0.41
FULL --- 0.54 --------- 0.77
Mine, 2001 vintage, was available LP or gas, virtually same generator The only difference in part numbers is fuel system parts and few sheet metal bits. Shows identical engine controls charging electronics etc.
LP: carb, regulator, LP solenoid
Gas: carb, fuel pump, filter
If you had owners manual it lists the different part numbers for both. Though I'd do more research it appears it may be as simple as swapping fuel systems ~$150. Quick look around parts available, carb, F/P.
Conversion seems simple enough. However fuel source isn't included, which to me is real hurdle.
Our camper projects page
