RV.Net Open Roads Forum: Class A Motorhomes: Leaving tow bar connected to MH
 > Leaving tow bar connected to MH
Wherever I happen to park
Posted: 07/07/20 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
The cons are:
Weather exposure if the RV is stored outside
Legs.. If it not bolted on and locked (As in with a key) it the can grow legs .
Home is where I park it.
RRTom
California USA
Posted: 07/07/20 03:42pm Link  |  Quote  |  Print  |  Notify Moderator
wa8yxm wrote:
The cons are:
It would be in a protective covering, and it would be locked. The motor home is backed in between our house and a block wall so the motor home (let alone the tow bar) is not noticeable.
2020 Georgetown GT 31LS
STBRetired
I-80 and I-55
Posted: 07/07/20 04:25pm Link  |  Quote  |  Print  |  Notify Moderator
Installed with a locking pin, sprayed with silicone lubricant according to manufacturer's instructions, and kept covered when not in use. Goes on when MH comes out of storage, comes off when MH goes to storage. No problems at all.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
TS21sso
North Central Texas
Posted: 07/07/20 05:14pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Blue Ox tow. bar, keep it on MH, covered with accessory vinyl cover. Remove it from MH once a year for cleaning, inspecting, and new grease on bars. Always clean and lube receiver before reinstall.
Dutch_12078
Winters south, summers north
Posted: 07/07/20 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Other than occasionally removing the tow bar for cleaning/lubing, it stays in place year round since we travel year round. I do install a weather cover when we're parked for awhile.
Dutch
2001 GBM Landau 34' Class A
Elk_traveler
maryland
Posted: 07/08/20 04:59am Link  |  Quote  |  Print  |  Notify Moderator
I have the Blue Ox and I always leave on. I place a cover on when I return home and detach the tow. Blue Ox has the rubber grommets and plastic spacers which enable movement of the tow bar these certainly would be affected by the heat and sun but once covered I think they're ok.
JoeH
Apollo Beach,FL
Posted: 07/08/20 05:31am Link  |  Quote  |  Print  |  Notify Moderator
Mine was put on the current coach 7 years ago... hasn't come off since.
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
Gjac
Milford, CT
Posted: 07/08/20 06:01am Link  |  Quote  |  Print  |  Notify Moderator
One possible con not mentioned is if you forget to put the locking pin in after you fold it can fall and drag on the road if no tow car is attached. This happened to me once when I went to get gas for the MH, thankfully a passing car told me that sparks were coming off the tow bar. I now use a bungee cord to keep the two legs from extending when no car is hooked up as well as the locking pin. Another minor problem is if left on for several years the lock going through the pin can rust and penetrating oil is need to open the lock.
