RV.Net Open Roads Forum: Toy Haulers: 2006 WW FSC3200 A/C Issue
Search only in Toy Haulers
 > 2006 WW FSC3200 A/C Issue
Lovesdunes
Descanso
Posted: 07/07/20 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Everyone. We have had this toy hauler since new. Have never had any electrical issues until this last week. The A/C will not come on. It was working great for 3 days, then the next day it would not do anything. I can hear clicking coming from the A/C intake in the ceiling when I slide the temperature setting up and down but that's about it. I replaced both capacitors in the A/C unit itself yesterday.
The fan does not blow in any setting.
Is there a circuit breaker for the A/C that I have forgotten about? I can't help but think this is an easy fix. I am OK with admitting operator error.
Lovesdunes
Descanso
Posted: 07/07/20 07:23pm Link  |  Quote  |  Print  |  Notify Moderator
Well after some more searching, I found the circuit breakers under the stove. I could have sworn there were pots and pans in there. Problem solved.
Y-Guy
Tri-Cities, WA
Posted: 07/08/20 05:56am Link  |  Quote  |  Print  |  Notify Moderator
Good deal, glad you solved the problem. Welcome aboard!
2007 Winnebago Sightseer 35J
2011 Jeep Wrangler
carringb
Corvallis, OR
Posted: 07/08/20 09:03am Link  |  Quote  |  Print  |  Notify Moderator
Great! But why did they trip? Are you plugged in at a park? If it tripped, the park power is probably dropping too low, and this alone will damage your windings in the A/C.
Bryan
2014 ORV really big trailer
2015 Ford Focus ST
Lovesdunes
Descanso
Posted: 07/08/20 11:32pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks. Lots of good reading here. Hopefully we will be getting out a little bit more. Trailer has been sitting for too long.
Lovesdunes
Descanso
Posted: 07/08/20 11:36pm Link  |  Quote  |  Print  |  Notify Moderator
The circuit breaker tripped from user error at the thermostat. My fault. I was setting the temperature and moved the temperature slider up and down too many times trying to get just the right temp. The A/C turning off and on too many times tripped the breaker.
nayther
Burbank, CA
Posted: 07/09/20 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Will happen every time. Compressor gets its cooling from the refrigerant flow. If it is not allowed to run long enough between starts it overheats, sometimes breaker trips, other times the compressor's internal overload trips and will only reset after it cools
we had that same t'stat in our Rage'n, did not like it for that reason. They sell a conversion kit that includes a digital thermostat, way mo betta.
DIRT BIKES RULE
'12 Duramax CC short bed
2019 Wildcat Maxx 285RKX
Lovesdunes
Descanso
Posted: 07/09/20 10:53pm Link  |  Quote  |  Print  |  Notify Moderator
That would be much better. We will definitely look into that. Thanks.
nayther
Burbank, CA
Posted: 07/13/20 11:01am Link  |  Quote  |  Print  |  Notify Moderator
I bought the kit from Benlo RV in Irwindale. Tom is the owner and super helpful.
