RV.Net Open Roads Forum: Fifth-Wheels: Ditching Dometic Thermostat?
 > Ditching Dometic Thermostat?
cavie
Posted: 07/09/20 03:42am Link  |  Quote  |  Print  |  Notify Moderator
time2roll wrote:
Super_Dave wrote:
Can I swap out my POS Dometic Thermostat with a simple household thermostat?
Not if it is digital.
Post the model number or a picture.
Why not? I have replaced 2 analogs with digitalis in two trailers
djousma
SW Michigan
Posted: 07/09/20 05:35am Link  |  Quote  |  Print  |  Notify Moderator
These thermostats are fine. I have the same ones, and had the same problems and frustrations as you. The problem I suspect with yours is that they had a bad batch of the touch screens causing the erratic behavior. Call Dometic customer service, describe the problem, and they will send you replacement face plates for free.
Since I have done that, the problem has completely gone away.
Dave
2016 F350 Lariat 4x4 FX4 SRW CC SB 6.7 Magnetic Metallic
2017 Forest River Cardinal 3850RL
sayoung
Tx
Posted: 07/09/20 06:41am Link  |  Quote  |  Print  |  Notify Moderator
One more time. The newer Dometic thermostat " talks " to the AC/furnace with a digital signal. The thermostat doesn't send the power directly to the fan relay & compressor contactor .
time2roll
Posted: 07/09/20 10:10am Link  |  Quote  |  Print  |  Notify Moderator
The wiring and communication is different on the new units.
cavie, Did your thermostat look like this?
These old and obsolete thermostats can be easily converted to a home unit.
When I say "digital" I mean the communication with the control box... not the LCD display.
* This post was edited 07/09/20 02:09pm by time2roll *
675w Solar pictures back up
Super_Dave
Harrisville, UT
Posted: 07/09/20 02:04pm Link  |  Quote  |  Print  |  Notify Moderator
So, per my picture, what do I have?
Truck: 2006 Dodge 3500 Dually
Rig: 2018 Big Country 3155 RLK
Boat: 21' North River Seahawk
Chris Bryant
Arden, North Carolina
Posted: 07/09/20 02:06pm Link  |  Quote  |  Print  |  Notify Moderator
Yours cannot be replaced without replacing the control box.
-- Chris Bryant
time2roll
Posted: 07/09/20 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
Is there a source to buy the old analog control box?
justme
Posted: 07/10/20 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
Just curious why you think it is a POS. Could you clarify?
Super_Dave
Harrisville, UT
Posted: 07/10/20 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
Justme, my living room thermostat is on the wall in my stairway to the bedroom. It gets bumped all the time and goes to a blank screen or switches to Celsius. Additionally, the air conditioner will run and time itself out before bringing temperature down to set temp. It requires turning the thermostat off for a minute and turning it back on to get it to continue running.
wvcampers
United States
Posted: 07/10/20 08:10pm Link  |  Quote  |  Print  |  Notify Moderator
Mine was doing the same as the OP. They will work great without the cover/touch pad. I called Dometic and explained what was happening and they sent me 2 whole thermostats. They are working like they should. They did have some bad ones. Give them a call.
2017 F350 6.7 CC Lariat DRW
2018 Cardinal Luxury Edition 3250 RLX
