RV.Net Open Roads Forum: Tech Issues: Locked out of RV
 > Locked out of RV
Monaramblee
Canada
Posted: 07/11/20 04:32am Link  |  Quote  |  Print  |  Notify Moderator
Try pulling the handle from different points of the handle ie place finger at one end of handle....or jerk the handle hard or pull handle into open position and try to put some weight into the pull on the door.
2008 Holiday rambler Vacationer XL
340 HP Cummins
ARMDR
Kansas
Posted: 07/29/20 10:43am Link  |  Quote  |  Print  |  Notify Moderator
I was on my third handle when a friend told me about a repair kit for the Trimark handle that I have. (T507/060-1650) I have bought 3 of the kits, and they're great. Takes 2 minutes to install, made out of stainless steel, and now I have 2 spare handles if someone else has the same problem. They're listed on Ebay.
pianotuna
Regina, SK, Canada
Posted: 07/29/20 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
ARMDR,
Do you have a link for the repair kit?
Regards, Don
ARMDR
Kansas
Posted: 07/29/20 01:31pm Link  |  Quote  |  Print  |  Notify Moderator
He has a website cartcollapse.com that has a link to buy using PayPal.
IAMICHABOD
Sunny So Cal
Posted: 07/29/20 01:41pm Link  |  Quote  |  Print  |  Notify Moderator
I have looked into This one
Along with the Video on how to do it.
Former El Monte RV Rental
Buying A Rental Class C
down home
south
Posted: 07/29/20 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
Son of Norway wrote:
This concerns the door latch below the deadbolt. I have the key. I have no problem locking and unlocking the latch, but I can't open the door with the outer latch. I pull on the latch and it won't open the door. The door isn't jammed, it acts like the latch is still locked.
So, I am locked out of my RV. All the windows and other ways to get in are closed and locked. There are no compartments or other ways to get in. I don't mind ruining the latch to get in, it needs to be replaced anyway. I have drills and other tools. I don't want to break a window.
What can I do?
Try pushing in on the door hard and pulling the handle or push in hard and use the key. Facility used the dead bolt yesterday instead of the fob and it didn't want to open.He came out and pushed n rel hard, the seal has a lot of compression, and I used the key and it opened right up.
Posted: 07/29/20 05:07pm Link  |  Quote  |  Print  |  Notify Moderator
My Tri-mark latch is a bit different than that but I had a shop make me a new striker bolt when the last one broke... Price for the one in the kit is reasonable
On my basement doors (Also tri-mark) slightly different bolt. Seneca Engineering in Seneca, SC carved me a batch of 'em I think about the same price.. Can't find the dang things so I used Plan B a few days ago.. (one of the many jobs I've held.... machienist.. I machine down the parts. mark, drill, tap and apply a standard steel mending bar to the "Backside (The long flat side) works great)
dedmiston
The West
Posted: 07/29/20 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
You need to hit the latch in juuuuuust the right place.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
pianotuna
Regina, SK, Canada
Posted: 07/29/20 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Thank you!
GrouchyOldMan
Open Road
Posted: 05/30/21 07:44am Link  |  Quote  |  Print  |  Notify Moderator
(I'm intentionally cross posting this to get the info out)
Same Problem, Best Solution!
After some research I purchased a Trimark Latch repair kit and I'm pleased with a complete and permanent fix for $49.
The kit includes a steel replacement piece, wrenches you'll need for the fix and a new spring, in case you lose yours like I did. This allows you to use your existing keys and it installs with no "modifications" needed which may not be the case if you just buy a brand new Trimark Lock.
To be fair, I have read that the new Trimark locks use a steel latch piece rather than the crummy pot metal ones that break.
The cartcollapse.com website doesn't seem to work anymore. Here are links to the Latch Fix website and the video showing how easy the fix is to do.
https://www.latchfix.com
https://www.youtube.com/watch?v=efW38pxwzZI
Cheers,
-Grouchy
* This post was edited 05/30/21 11:20am by GrouchyOldMan *
 > Locked out of RV
