RV.Net Open Roads Forum: Beginning RVing: Are RV sewer hose supports necessary?
 > Are RV sewer hose supports necessary?
Page of 7
dcmac214
SW OKLA
Posted: 07/12/22 11:26am Link  |  Quote  |  Print  |  Notify Moderator
No, not necessary. We use one whenever the hose isn't all-downhill from RV to sewer pipe, which is probably +90% of the time.
Alan_Hepburn
San Jose, Ca, USA
Posted: 07/12/22 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
There are some municipal codes that require the sewer hoses to be elevated off the ground, so it's wise to at least carry a "stinky slinky" for those times where the campground requires it...
Alan & Sandy Hepburn driving a 2007 Fleetwood Bounder 35E on a Workhorse chassis - Proud to be a Blue Star Family!
Good Sam Member #566004
way2roll
Wilmington NC
Posted: 07/12/22 12:40pm Link  |  Quote  |  Print  |  Notify Moderator
Little surprised at the answers. I have a set and use them just about every time I am at a site with full hookups. I don't use them at a dump station of course, but I find that at a site the port is always a few inches tall and the supports help overcome the hump. Also, without any support, I find the sudden rush of opening the valve really pulls on the connection point of the hose to the RV and keeps the hose from getting a little squirrely. It also keeps the hose off the ground and getting muddy etc. Only takes a minute to set them up and provide the easiest way for a straight shot. To each his own. I just never realized so many people were against them.
2023 FR Sunseeker 2400B MBS
Cocky_Camper
Rock Hill, SC
Posted: 07/12/22 01:12pm Link  |  Quote  |  Print  |  Notify Moderator
The only that that we have used one is if the rv outlet is lower higher than the ground drain, but the ground would run uphill. And 2, sometime is the hose if to long for the area, it just helps to keep it in place that that it want snake all over the ground.
2004 Sea Breeze by National RV - 8341
Former Coaches:
2006 Keystone Zeppeline 291 - TT
2000 Aerolite Cub F21 - Hybrid TT
1991 Coleman Pop Up
Formerly known as: hybrid_camper
Campinghoss@51
Windsor NC
Posted: 07/13/22 09:36am Link  |  Quote  |  Print  |  Notify Moderator
I use mine as well. As far as being surprised, there are a lot of things talked about in this forum that surprise me [emoticon]
Camping Hoss
2017 Open Range 3X 388RKS
2017 F-350 6.7 with hips 8'bed
Lucky & Lucie
valhalla360
No paticular place.
Posted: 07/13/22 10:00am Link  |  Quote  |  Print  |  Notify Moderator
6door74 wrote:
Just rented a travel trailer for a few days and noticed almost everyone had these but me. I found myself walking the hose to empty it and not sure if it's related, but found that the hose leaked it i didn't squat down and hold it against the outlet. I watched my neighbor dump his tanks while doing other things to break down, meanwhile i was stuck holding the hose.
While we don't own a trailer yet, i think I'll purchase these supports so i have them in future for rentals and eventually ownership.
If the fittings are loose on the connection, they will leak whether you use a support or not.
If we will be in place for more than 4-5 days, we will use it, so we can just pull the valve to drain the next time.
If it's less than 4-5 days, we will just hook up the hose and drain before leaving...no point in messing about with the support.
PS: you still want to flush with straight water as the ribbed design of the hose will hold debris otherwise.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
mdcamping
CT
Posted: 07/18/22 06:34am Link  |  Quote  |  Print  |  Notify Moderator
Bobbo wrote:
mdcamping wrote:
only boondocked once or twice, my trailer has a low sewer connection, been multiple times where my accordion sewer hose supports has come in handy on full hook up sites.
Mike
How did they come in handy above just laying the stinky slinky on the ground?
Just noticed this thread and yeah I know this is a 2yr old reply, I have come across sewer connections where they were 6" or 8" above ground, combine that with the connection area being in a ditch I end up with water having to flow uphill. The slinky came in handy to bridge the ditch area.
I may not need it as much with my new trailer as I have a higher sewer connection, but if i need it I'll use it.
Mike
* This post was edited 07/18/22 06:44am by mdcamping *
2022 F-150 3.5 EcoBoost 4X4 Supercrew GCWR 19,500 157WB
Payload 2476 Maxtow 13,800 3.73 Equalizer 4 Pt Sway Hitch
2017 Jayco Jay Flight 24RBS
Old TV, 07 Toyota Tacoma, Double Cab, Factory Tow Pkg, retired towing at 229K. (Son now owns truck)
pbeverly
South Carolina
Posted: 07/19/22 04:39am Link  |  Quote  |  Print  |  Notify Moderator
I'll walk my slinky when done draining. Takes a whopping 10 seconds if even that. As long as the trailer discharge is a little higher that the sewer connection gravity will work, even if it has to go up a bit at the sewer. The initial gush of grey water should push what is left of the black water on thru. I have never had the experience of a sewer connection being higher than my camper.
I once watched a guy spend 2 hours plus getting his slinky and supports PERFECT. No exaggeration. Maybe if I was staying somewhere LONG term, but he was only there for a couple days. Probably didn't use his tanks out all.
I wonder how many people who use supports are trying to skip using their tanks.
Ridgeway, SC
dave54
Northeast CA.
Posted: 07/29/22 10:42pm Link  |  Quote  |  Print  |  Notify Moderator
Carry one. Seldom use it. Only if the ground is uneven or gravel (low spots and gravel poking holes in the hose). I have run across a few campgrounds that require them.
One time the hookup was so far back behind the site I had to go buy a second support to reach.
Another time the site was so uneven the in-ground sewer drain was above the rig drain port. Had to repeatedly walk the hose to the drain.
* This post was edited 08/05/22 02:11pm by dave54 *
So many campsites, so little time...
Sjm9911
New Jersey
Posted: 07/30/22 06:30am Link  |  Quote  |  Print  |  Notify Moderator
I always use mine when set up , makes it easier. Hows that saying go, #%@! Flows downhill? The support makes it so. Also, easier to clean when done. I also have had to walk mine when they have the really high conections, not exactly an ideal task. Much easier to have gravity do the work for me.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Page of 7
