RV.Net Open Roads Forum: Beginning RVing: Are RV sewer hose supports necessary?
 > Are RV sewer hose supports necessary?
Page of 8
Cptnvideo
Arizona - most of the time
Posted: 07/30/22 11:01am Link  |  Quote  |  Print  |  Notify Moderator
I bought a 10' length of gutter (about $6) at a local hardware and had them cut it into 4' and 6' sections. I lay one or the other or both on the ground if a puncture might occur. And I put a block of some sort under one end if I need to create a ramp.
Bill & Linda
Arizona
2019 Dodge Ram Laramie 3500 dually 4x4 diesel
Hensley Trailer Saver BD5 hitch
2022 Grand Design Solitude 378MBS
1600 watts solar, Victron 150/100 MPPT controller, GoPower 3kw inverter/charger, 5 SOK 206AH LiFePo4 batteries for 1030 ah
Veebyes
Posted: 07/30/22 02:53pm Link  |  Quote  |  Print  |  Notify Moderator
One more thing to find a place to store it.
Don't dump if you don't need to. We can go a week no problem but usually dump every 3 or 4 days or depending on availability of a dump.
No big deal to hold the hose up & let gravity do it's thing.
2007 Alpenlite 34RLR
WinMinnie02
NJ
Posted: 07/31/22 06:07am Link  |  Quote  |  Print  |  Notify Moderator
No the sewer hose support is not necessary. Have not used my in 15 years, waste of money.
4x4van
California
Posted: 08/09/22 11:21am Link  |  Quote  |  Print  |  Notify Moderator
Been RVing for 30 years. Used an extendable plastic support (similar to PVC cut in half) a few times when first starting out, but it hung on the RV sewer outlet and was never "quite right", so eventually stopped and just "walked" the hose. About 5 years ago, decided to try one of the expanding slinky type. Used it exactly once; finally gave it away as it was more work than it was worth, and took up space.
I typically only hook up electric. Use water from my tank, and will dump at the end of the trip (or earlier if needed). The support is just another thing to set up and take down, which takes longer than simply walking the hose after dumping.
We don't stop playing because we grow old...We grow old because we stop playing!
2004 Itasca Sunrise M-30W
Carson enclosed ATV Trailer
-'85 ATC250R, '12 Husky TE310, '20 CanAm X3 X rs Turbo RR
Zieman Jetski Trailer
-'96 GTi, '96 Waveblaster II
WinMinnie02
NJ
Posted: 05/15/23 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
No
bikendan
Goodyear, Arizona
Posted: 05/16/23 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
WinMinnie02 wrote:
No
Not sure where you camp but saying No, is incorrect.
Many RV parks and campgrounds require them for full hookup sites.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
Bobbo
Wherever I park
Posted: 05/16/23 07:53pm Link  |  Quote  |  Print  |  Notify Moderator
No, you don't need them for efficient dumping of your tanks. If your campground requires them, that is a totally different discussion.
Bobbo and Lin
JoeH
Apollo Beach,FL
Posted: 05/17/23 05:44am Link  |  Quote  |  Print  |  Notify Moderator
a couple months ago, we were in Maricopa County, Arizona and were told that the county requires use of elevated sewer hoses... luckily I had a hose trellis stashed away .
Joe
2013 Dutch Star 4338- all electric
Toad is 2015 F-150 with bikes,kayaks and Harley aboard
way2roll
Wilmington NC
Posted: 05/17/23 05:45am Link  |  Quote  |  Print  |  Notify Moderator
I just find it interesting that a 3 year old thread has been randomly resurrected twice.
And FWIW this question is completely subjective to the user. So many variables not the least of which is the placement, height and angle of your dump valves and where you are camping and the angle and placement of the hookup. I have them. Sometimes I use them, some times I don't. I go by the rule - better to have it and not need it than need it and not have it.
2023 FR Sunseeker 2400B MBS
StirCrazy
Kamloops, BC, Canada
Posted: 05/17/23 07:00am Link  |  Quote  |  Print  |  Notify Moderator
I use one, it takes 3 seconds to set up and only costs about 30 bucks. dumping is much easier as you gave a gradual slope. When I am camping with the 5th wheel and have hookups, I leave the dump valves for the gray open all the time, so I don't have to worry about the shower filling stuff up and then only dump the black when it needs it.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
Page of 8
