valhalla360
No paticular place.
If it's only a night or two, just don't leave it hooked up and it's not an issue.
Usually they require them if you will leave it hooked up. Basically, they don't want the hose sitting there full of liquid. Most sewer hoses are thin and weak, so they don't keep odors in well and they are prone to pinhole leaks.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Two yes answers
First there are a few places which have a rule that requires them. When I returned to MI this summer I spent a couple nights in a campground that did so. (Since I did not dump there no problem I used some fresh water but that's all) the other place is Clark County (Las Vegas) Nevada.
The other yes answer is the supports keep the hose off the ground. Some hoses are not all that puncture resistant and can be damaged by rocks on the ground.
rwess
Georgia
I do not use one while camping. It is a simple matter of hydraulics. If the camper outlet is higher than the sewer opening, eve if the sewer opening is raised. The incoming water from the camper will push whatever is in hose on through and down the sewer.
Of course you must have a hose with no leaks. After 24 years of campers I have never had a problem. I have never stayed anywhere that required one.
rwess
USN Ret.
2017 Open Range 216RBS
2010 Chevy 2500HD Z71 4x4 LT
Veebyes
12 years of hundreds of dumps in hundreds of CGs & have not seen a need for a slinky yet. Rarely stay anywhere for more than 5 nights. Rarely use a FHU site. 5 nights without dumping is easy.
At the CG dump if the sewer is higher than ground level picking up the hose & 'walking' whatever to the sewer is easy.
2007 Alpenlite 34RLR
Bobbo
Wherever I park
No, they are not. IF the hose fills up because the outlet is raised, wait for it to stop running, then lift the end nearest the trailer and walk it to the drain. Do that 2 or 3 times and the hose will be empty. (Be sure the drain valve is still open to vent the hose while doing that.) In 14 years, I have never used one, never seen the need for one, and never been in a campground that required one.
Bobbo and Lin
kellem
Shenandoah valley,VA
20 yrs, weeks at a time with full hookups and never used them.
It's obvious that they would provide some mechanical efficiency but simply something else to carry.
BobsYourUncle
Calgary Alberta Canada
I dont like those expandable adjustable slinky stands, I dont want to fiddle with them.
I ran into a situation at a nice CG on a lake a few years ago where my site had the hookups on the wrong side for me to face the lake when set up.
I drove out to a local building supply store, bought a 10 foot length of 4" PVC pipe, drew a line lengthwise on both sides, pulled out my cordless reciprocating saw and cut the pipe in half lengthwise.
I carry several lengths of slinkies, coupled them together and tied my half pipe at the drain outlet, running it to the drain via under my TT. A few blocks in the right place allowed it to fully drain properly.
Works like a charm. I carry it in the back of my truck now when we camp. Simple and easy to use.
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
Big Katuna
Deland, FL
I carry one. We half time. I use one occasionally for a reason I haven’t read yet and why I bought one.
We camped at a campground And the dirt around the pad was red clay. After a week of on and off rain the sewer hose was coated with red clay. A real dog to clean off.
So I bought a support to use when it’s a muddy site.
My Kharma ran over my Dogma.
jdc1
Rescue, Ca
Waste of money, time and space. But, it you want to help with the economy.....
BB_TX
McKinney, Texas
On the other hand, I always use mine. After draining the tanks the slinky is also fully drained. I watch others "walking" the water out of their slinky that was laying on the ground with the park dump pipe several inches above ground and wonder why people don't use them. Folded up it takes very little room. And it keeps the slinky off the rough concrete or paved or gravel site pads.
