RV.Net Open Roads Forum: Beginning RVing: Are RV sewer hose supports necessary?
 > Are RV sewer hose supports necessary?
Page of 5
Turtle n Peeps
California
Posted: 07/18/20 09:08am Link  |  Quote  |  Print  |  Notify Moderator
Is it necessary? In 40+ years of camping and 24 states I have never used them.
So for me; it's not necessary.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
dave54
Northeast CA.
Posted: 07/18/20 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
Used to use them. Seldom do now. Most sites are level enough they are not needed. A few places had signs stating supports were required by local code. Supports do keep the hose off sharp rocks that could poke a hole.
Had one site so sloped the sewer was above my outlet. That made dumping my tanks a challenge but I figured out a workaround.
So many campsites, so little time...
spoon059
Just north of D.C.
Posted: 07/28/20 09:31am Link  |  Quote  |  Print  |  Notify Moderator
Like others, I don't use the traditional supports. I have a 10'section of plastic gutter that I cut into a 6' and 4' piece. If I need to control the angle of my sewer hose, I lay it in the gutter and use blocks to control the angle. The traditional supports allow the hose to sag between supports and don't really work if the ground isn't even.
* This post was edited 07/28/20 09:37am by spoon059 *
2015 Ram CTD
2015 Jayco 29QBS
Powertour
Nevada
Posted: 07/31/20 05:37am Link  |  Quote  |  Print  |  Notify Moderator
In 20 years I can probably count on 1 hand the times I've had to or would've been nice to use one if I'd had one with me.
We carry a standard camco (or whatever brand it is) expandable one with us nowadays but it rarely gets pulled out of the storage compartment.
2015 Itasca 25b Ford E350 V10
pitch
NY
Posted: 08/02/20 07:52am Link  |  Quote  |  Print  |  Notify Moderator
We have a set and use them probably 30% of the time. Our Hybrid is low and we don't get that powered gravity slam that most,(taller), get.
While not critical for the price why not?
SamanthaNichols
2046 Hillcrest Drive Tacoma, WA 98402
Posted: 08/10/20 07:32pm Link  |  Quote  |  Print  |  Notify Moderator
I used Camco Sidewinder for what it was designed for, support of RV sewer hose. Like products that really do what they were intended for. This product is rugged and worked very well. The only question is how long the plastic locks for vertical pins will last. They functioned very well. Rugged, provides super support for hose, especially over rough surfaces with changes in elevations. They can be set at angles as shown in the attached photo. The notch inside held the hose firmly. Now you need to realize that this takes a few more minutes to set up over the accordion support. Also, be aware that they do take about 10inches by 35 inches by a foot high for storage. All said these should last for years and will not break apart like the accordion-style plastic support. Very satisfied with this product, hope this helps someone with their purchasing decision.
Page of 5
