RV.Net Open Roads Forum: Travel Trailers: Life of AC?
 > Life of AC?
midnightsadie
ohio
Posted: 07/11/20 04:58am Link  |  Quote  |  Print  |  Notify Moderator
breaker is cheap change it, just a cheap try. they weaken after being trip alot. lowes home depot.
valhalla360
No paticular place.
Posted: 07/11/20 05:17am Link  |  Quote  |  Print  |  Notify Moderator
It's possible it's failing but 3-5yrs is no where close to typical.
If you have it plugged in running at home all the time, how are you protecting it from low voltage?
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
12th Man Fan
Flower Mound , Texas
Posted: 07/11/20 07:34am Link  |  Quote  |  Print  |  Notify Moderator
Check all of your wiring connections in the back of the breaker panel.
Be sure to unplug first.
2014 GMC Duramax 4X4 DRW Crew
2015 DRV Tradition
jdc1
Rescue, Ca
Posted: 07/11/20 09:22am Link  |  Quote  |  Print  |  Notify Moderator
colliehauler wrote:
If it was run on low voltage it could need replaced. Low voltage will destroy a A/C unit.
Tell me about it. LOL.
kellem
Shenandoah valley,VA
Posted: 07/11/20 09:43am Link  |  Quote  |  Print  |  Notify Moderator
I personally will not hookup at the CG pedestal without a quality EMS " electrical management system ", not the cheap ones that merely display an issue but offer no protection.
Most common issue is the AC compressor burns out from low voltage.....yes the breaker does offer some protection but nothing near what a quality EMS can do.
I've been using a progressive industries EMS-PT30X, also here good reviews with Autoformers.
Gulfcoast
Alabama
Posted: 07/11/20 10:14am Link  |  Quote  |  Print  |  Notify Moderator
Put a start kit on it
Start Kit
KD4UPL
Swoope, VA
Posted: 07/11/20 10:58am Link  |  Quote  |  Print  |  Notify Moderator
When I solar my camper the AC unit was 15 years old. It still worked great.
I would try a new breaker first, that will only cost you about $5 for the breaker and 10 minutes to change it.
There's no way 3 to 5 years is a normal failure time frame.
theoldwizard1
SE MI
Posted: 07/11/20 04:04pm Link  |  Quote  |  Print  |  Notify Moderator
A TRUE "soft starter" is much more than just a capacitor. Yes, a bigger capacitor will help, but what you need is some "smart" electronics that limit the current for a second or two until the motor starts spinning before "giving it the gas" !
MicroAir EasyStart
Gulfcoast
Alabama
Posted: 07/11/20 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't put $300 into a 6 year old a/c., I put the $10 kit on mine last week. nice
fla-gypsy
North Florida
Posted: 07/11/20 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
I’m 15 years into my current one. Replaced a condenser fan last year finally
This member is not responsible for opinions that are inaccurate due to faulty information provided by the original poster. Use them at your own discretion.
 > Life of AC?
