RV.Net Open Roads Forum: Tow Vehicles: 2017 Chevy as tow vehicle
Search only in Tow Vehicles
 > 2017 Chevy as tow vehicle
wtmtnhiker
New Hampshire
Posted: 07/11/20 05:04am Link  |  Quote  |  Print  |  Notify Moderator
Hi all,
I'm looking at a 2017 Chevy Silverado half ton with a 5.3L engine and 3:32 ratio rear axle and 37k miles. I know it has plenty of pulling power for what I need but will it be a dependable vehicle? It has the Active Fuel management which I'm a bit leary of. Is this system reliable? Seems a little clunky to me. I'd like to hear from those of you who have actual ownership experience with and especially those of you who have been towing with one.
Thanks
bgbassman(bluegrass bass man)
eHoefler
ozark mountains
Posted: 07/11/20 05:34am Link  |  Quote  |  Print  |  Notify Moderator
Really not a towing vehicle, more like a grocery getter. High axle ratio will indicate a lower towing capacity.
2019 Ram Limited, 3500, Crew Cab, 1000FTPD of Torgue!, Max Tow, Long bed, 4 x 4, Dually,
2006 40' Landmark Mt. Rushmore
Sjm9911
New Jersey
Posted: 07/11/20 05:40am Link  |  Quote  |  Print  |  Notify Moderator
Is the active fuel managment the cylinder shut off thing to meet the mpg requirements? If so , i didnt like it. I had a 2012 sierra, with the same engine maybe better gear ratio. And max tow package. Problem was that ot took time for the computer to activate the engine when you stepped on the gas. Not too much of a concern driving but towing was a pita on the highway. Maybe the bugs were worked out by 2017. Otherwise the truck was great and smooth. I got a 2500 this year.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
A1ARealtorRick
Gulf Shores, AL
Posted: 07/11/20 05:51am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone thought to ask the OP what he's towing with it? Anyway, he's asking about dependability, not towing capacity. If he's pulling a Scamp or an Airstream Bambi, we'll look pretty silly giving him towing advice!!
. . . never confuse education with intelligence
wtmtnhiker
New Hampshire
Posted: 07/11/20 06:02am Link  |  Quote  |  Print  |  Notify Moderator
I'm towing a Grand Design Imagine GVW under 7K and it's a 4:42 ratio
jerem0621
Tennessee
Posted: 07/11/20 06:39am Link  |  Quote  |  Print  |  Notify Moderator
I tow with my 2011 Tahoe with the same 6 speed trans and 3:08 gears. Does great. My 5.3 has the AFM (or DOD, it’s the same thing) and it works great. We are nearing 140k. I run fully synthetic oil only and I change the oil when the OLM gets to 50% because I tow a lot. (My camper and my father in laws big pontoon boat)
3:27 would pull better than my 3:08 but with the 6 speed my 3:08’s do great.
My TT is 7,000 ish lbs loaded and 11 ft 2 Inches tall.
Trans temps rarely top 180° and pulls like it’s on rails. Love my Chevy.
Thanks!
Jeremiah
TV- 2011 Chevy Tahoe, 2WD, Hayden transmission cooler
TT - Zinger 270BH
WD Hitch- HaulMaster 1,000 lb Round Bar
Dual Friction bar sway control
Tekonsha Voyager brake controller (Great Brake Controller)
It’s Kind of Fun to do the Impossible
~Walt Disney~
APT
SE Michigan
Posted: 07/11/20 06:43am Link  |  Quote  |  Print  |  Notify Moderator
Please recheck the axle ratio. If you are able to look at the sticker in the glove box for RPO codes, look for GU4 or GU6 which are most common.
The 5.3L has been around for over 20 years with refinements over the years. There are plenty of them with over 300k miles. GM's small blocks are some of the most reliable and cheap to maintain of any engines.
2017 Subaru Outback 3.6R
deltabravo
Spokane, WA
Posted: 07/11/20 06:44am Link  |  Quote  |  Print  |  Notify Moderator
What is 4:42?
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
wtmtnhiker
New Hampshire
Posted: 07/11/20 06:45am Link  |  Quote  |  Print  |  Notify Moderator
You're right sorry it's 3:42 ratio rear axle
blt2ski
Kirkland, Wa
Posted: 07/11/20 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Most common AR is 3.43, next 3.08, very rare a a 3.73 behind that motor. I believe grit dog is pulling upwards of 10k with his work rigs. Granted equipment trailers vs an RV trailer.
Altho someone above commented on tall axle ratio, the 6 so auto has a 4.10 in first gear. So overall low is better than my C2500 with 4.10s in axel, and a supertall 2.48 in trans.
I personally would not worry about it. I've been looking at 4 3s with 3.23 in red, or 3.42 in 4wd. Not worried about it towing a 7000 lb trailer with a mini excavator.
Marty
Check RV.Net Blogs at: blog.rv.net
