RV.Net Open Roads Forum: Cleaning Black AC cover and other black items
 > Cleaning Black AC cover and other black items
purplekeenah
greensburg, pa
Posted: 07/16/20 08:05am Link  |  Quote  |  Print  |  Notify Moderator
Kreylon rattle can works for me, and it will stay colorfast for a few seasons. For $6.00/can at Walmart it works very well, especially if you want to color match the A/C shrouds to the body which I did with my last rig.
2015 Newmar Dutchstar 4369
2013 Chevy Equinox
kfp673
PA
Posted: 07/16/20 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
kellem wrote:
kfp673 wrote:
Sounds like 303 is the winner. Never tried it. I assume it's OK to use even if some gets on the rubber roof? Thanks all!
Well I hope it is.....I rub down the entire trailer and roof with 303 every 2 months and it's sustained it's new appearance.
Just use a car wash mop, only takes an hour with 30ft trailer.
Go through about a gallon per year, Amazon.
Interesting. Do you wet the mop or just spray it on and use the mop to spread it? Also, do you was the sides as well or only use 303? Thanks for the reply!
kellem
Shenandoah valley,VA
Posted: 07/17/20 06:58am Link  |  Quote  |  Print  |  Notify Moderator
Simply spray it on then mop it out, leaves a rich shine and valuable sun protection.
When washing the trailer is a must " not often " I use Dawn dish liquid and let trailer dry completely before applying 303.
A wash and wax would compromise the 303's ability to adhere.
Duration of product ?
Roof beads water for approximately 2 months,sides and seals go a little longer.
Very satisfied with ease of application and how it keeps the vulnerable front cap and decals looking new.
Be careful on the roof.
* This post was edited 07/17/20 07:26am by kellem *
kfp673
PA
Posted: 07/31/20 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
Hello all- So I did end up going with 303 for all of the black plastics and trim on the camper. Looks great until it rains and then it runs like crazy. I made sure to really wipe it in and in most cases spray on the rag to apply, so I do not feel it was overused. Tried it again yesterday for certain areas. Again looks fantastic when done, but it rained this morning and those black plastic items are all streaky again. Any thoughts?
Wherever I happen to park
Posted: 07/31/20 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
Seriously you have BLACK covers.. Believe it or not WHITE makes them work better.
Home is where I park it.
Thermoguy
Graham, WA
Posted: 07/31/20 07:03pm Link  |  Quote  |  Print  |  Notify Moderator
I use F11 on the trim and mirrors on my truck. Doesn't wash off. Expensive but I do the entire truck and have done the front of my trailer. It's basically a detail spray but you can put it on everything. Even great on Stainless steel.
hondapro
Central Pa
Posted: 08/01/20 06:34am Link  |  Quote  |  Print  |  Notify Moderator
303 is a very good product but I think it works best to keep it from fading in the first place.If it has already faded. The 303 will make it look black as you found out,but won't last long. Once it faded I think you will need to paint it or replace it.
Steve
2016 F-350 6.7 Diesel
2015 Springdale 311RE
RAS43
Littleton,CO
Posted: 08/01/20 06:47am Link  |  Quote  |  Print  |  Notify Moderator
I agree. I see so many newer RV's with black or dark colors being used in many applications. RV's are hard enough to keep cool but those dark coolers increase the heat load.They may look great but builders should know better.
Not sure, wear a white shirt outside on a sunny day. Then put on a black shirt. Big difference!
Lynnmor
Red Lion
Posted: 08/01/20 06:58am Link  |  Quote  |  Print  |  Notify Moderator
The builders will build anything that sells, what makes sense isn't even on the chart.
