RV.Net Open Roads Forum: Tow Vehicles: Good truck for towing
Search only in Tow Vehicles
 > Good truck for towing
Sjm9911
New Jersey
Posted: 07/12/20 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
He's going full time, that means more stuff. Get a 2500.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
camp-n-family
London, Ontario
Posted: 07/12/20 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
For full timing get the 2500 and skip the 5.7. Get the 6.4 for better power and fuel economy.
'17 Ram 2500 Crewcab Laramie CTD
'13 Keystone Bullet Premier 310BHPR
Hitched by Hensley
HappyKayakers
Somewhere in the USA
Posted: 07/12/20 09:50pm Link  |  Quote  |  Print  |  Notify Moderator
Go to this website Trailer Life Towing Guides and check the specs for different options. It will give you a much better picture of your towing capacity. Of course, you still need to figure out how much additional weight you'll be putting in the trailer and the truck.
Joe and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
Campground Tees
bikendan
Camano Island, Wash.
Posted: 07/13/20 03:13am Link  |  Quote  |  Print  |  Notify Moderator
the vehicle manufacturer's Towing Guides are much more accurate, than what TL publishes.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
APT
SE Michigan
Posted: 07/13/20 07:09am Link  |  Quote  |  Print  |  Notify Moderator
I recommend a truck with at least 8k tow rating, at least 1700 pound of payload. You can find that in some half tons and almost every 3/4 ton.
2017 Subaru Outback 3.6R
valhalla360
No paticular place.
Posted: 07/13/20 07:37am Link  |  Quote  |  Print  |  Notify Moderator
jdc1 wrote:
Even better, find a used 2500 diesel
Even full timing, unless you are planning crazy numbers of miles, you likely won't recover the cost of diesel. Now if you find a deal...that's a different question.
A 3/4 ton does make sense for a full timer as it's less likely to have a "tail wagging the dog" situation as everything is bigger, heavier and stronger.
As others have said, go with the max loaded weight of the trailer for your early estimates (GVWR) and then figure out what is likely to be in the pickup (firewood, gas jugs, bed cap, etc...) as the hitch weight comes off your payload.
If you go 1/2 ton, make sure it has the heavier payload options (they can be as low as 1300lb to over 2400lb, so simply saying 1/2 ton can have a lot of variability). Payload will likely be your limitation with a 1/2 ton.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
deltabravo
Spokane, WA
Posted: 07/14/20 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto.
For full time travel, DIESEL all the way.
There's about a dozen people I follow on Youtube that are full timers, they all have a diesel truck and say for the amount of traveling they do, they'd never go with a gas truck.
I've had my diesel truck since 2009. I will never go back to gas as my primary tow vehicle.
2018 Timber Ridge 24RLS (bought pre-owned 3/12/20)
packpe89
NC
Posted: 07/21/20 06:02am Link  |  Quote  |  Print  |  Notify Moderator
Is the 30' total length or just the box. Getting close to dog wagging the tail. I would go with a 3/4 ton, and like diesel for mountains and for ease of fill-up (truck stops) while towing.
kellem
Shenandoah valley,VA
Posted: 07/21/20 08:34am Link  |  Quote  |  Print  |  Notify Moderator
You'll be full timing, definitely 2500.
6.4 Hemi will handily pull that trailer up any pass in US as would 6.6 Chevy and 7.3 Ford.
Skelshy
Pacific Northwest
Posted: 07/21/20 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
New 1/2 ton will do this easily. For reference, here is the Ford towing guide:
https://www.fleet.ford.com/towing-guides/
Buying used, really depends.
