RV.Net Open Roads Forum: Class C Motorhomes: RV carport/shelter
 > RV carport/shelter
campbrojo
NC
Posted: 07/12/20 11:42am Link  |  Quote  |  Print  |  Notify Moderator
Hi folks- I searched around a bit but I didn't find any information that might answer a question I have about metal RV shelters.
We have a Winnebago 31' class C which is 9'6" high on the sides. The a/c unit adds more height.
We are trying to see if anyone uses a metal shelter an what side height you have.
Thanks.
2004 Winnebago Minnie Winnie WF311C
Hank85713
Tucson, Az
Posted: 07/12/20 11:58am Link  |  Quote  |  Print  |  Notify Moderator
You will need a minimum of 12ft sides and if you will have a door you will need to probably go to 14 ft. We just had a 40x50 shed built 14ft eaves, so we can have a 13 ft roll up door. There are many variable in having what you want built, local codes are the biggest factor. I had built a temp tin shelter and had 10ft eaves and it was very close on getting TT in as I had to remove center poles and then reinstall after siting. Out here there are many carport types 8-10 wide with about 12-15ft eaves. These are standard 8ft eaves which have extensions to raise them. Had one at a place I worked for outside maintenance activities, see them around the area for rv storage. Check with your search engine for metal buildings storage in your area to get an idea. My c is about 12 ft high went with higher door in case we ever decide to up grade (doubtful).
example this is pic of double, rvs can be simple single but you get idea. http://www.westernstatesmetalbuildings.com/tucson-metal-carport/
bukhrn
Lanexa, Va
Posted: 07/12/20 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is is 20x40 for my 29" class C , I have 3 sides closed with the front open, (no door) my RV is 11' 4" to top of AC, my front opening is 12ft.
This is the co. I used.https://www.carolinacarportsinc.com/
* This post was edited 07/12/20 12:14pm by bukhrn *
2007 Forester 2941DS
2014 Ford Focus
campbrojo
NC
Posted: 07/12/20 12:48pm Link  |  Quote  |  Print  |  Notify Moderator
I've gotten some quotes from this Carolina Carports. They said a 10' side wall goes to 11' 6" center peak height. I'm looking to see what height the side wall would be.
campbrojo
NC
Posted: 07/12/20 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Not looking for a door. Just one side and the back enclosed. No eaves either. Stricly a canopy and one side closed to keep the southern exposure of the camper covered.
Beverley&Ken
Tottenham,Ontario
Posted: 07/12/20 02:10pm Link  |  Quote  |  Print  |  Notify Moderator
I just measured our 29b and it is 9'6" from the ground to the extrusion at the top of the side. Then there is the sharp curve where the roof meets the sidewall. + 3 1/2", then the fridge vent on the sloped roof + 4". So just in from the side I'm over 10'.
Don't forget the ladder going up and over, mine is on the back but realtivley close to the side, max air covers.
I would go with a 12' wall, maybe 11' IF the framework went to a minimum clearance of 12'+. That would be the minimum if you are backing under from a level driveway.
Ken
2006 Winnebago Outlook 29B E-450.
2012 Honda CR-V AWD
Blue Ox Aventa LX tow bar and Brake Buddy Vantage.
midnightsadie
ohio
Posted: 07/12/20 03:50pm Link  |  Quote  |  Print  |  Notify Moderator
call your local builder they,ll make it to your needs no guessing ,guy up the road has one half sided works for him. p.s anchor it well.
ferndaleflyer
everywhere
Posted: 07/12/20 04:24pm Link  |  Quote  |  Print  |  Notify Moderator
Carolina Carports is probably the most experienced in these parts. They go up in WV, Down in SC and probably more places than that. You tell them what YOU want and they will build it....depending on where in NC you are you might need some strength for snow. No builder will get close to those folks for a purpose built shed and usually done in a day
Charlie D.
E. Texas-Orange
Posted: 07/12/20 06:42pm Link  |  Quote  |  Print  |  Notify Moderator
Little confused here. Based upon what you said the wall would be 10'.
Measured mine and side wall is 12'before the arch is added and 15'3" at the center peak. Overall mine is 24'wide by 40'.
What ever you do make sure it is long enough to protect the camper on the open end.
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
Williams AZ area
Posted: 07/12/20 07:06pm Link  |  Quote  |  Print  |  Notify Moderator
“class C which is 9'6" high on the sides. The a/c unit adds more height.”
So at this point you don’t know the height of your C. Time to measure carefully.
