RV.Net Open Roads Forum: Travel Trailers: Replacing Microwave
 > Replacing Microwave
atrerice
Michigan
Posted: 07/13/20 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
The original Dometic microwave started malfunctioning towards the end of last season and now, the keypad is completely erratic when you push the buttons. Rather than purchase an RV type microwave with the trim pieces, I purchased a standard home tabletop microwave that fits the opening. Does anybody have any suggestions on how to fasten it down so it doesn't bounce around while underway?
guidry
Texas Cajun
Posted: 07/14/20 05:31am Link  |  Quote  |  Print  |  Notify Moderator
Look at something similar to earthquake water heater straps. Smaller situation but similar design. I replaced my original with one from Walmart under the cabinet and it worked fine. But since you opted for a table top version, you’ll have to screw down something to hold it. Good luck
midnightsadie
ohio
Posted: 07/14/20 05:33am Link  |  Quote  |  Print  |  Notify Moderator
mine just sits in the hole ,has a little ledge out front about 1/2 tall. you could put just a dap of silacone under each ft. mines 12years old never moves.
enblethen
Moses Lake, WA
Posted: 07/14/20 07:20am Link  |  Quote  |  Print  |  Notify Moderator
Neighbor Microwave went bad. We were able to use trim from the old one.
Perforated pipe strapping works. Nylon strapping from tie downs could be better to tighten more with a little stretch.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
jdc1
Rescue, Ca
Posted: 07/14/20 07:35am Link  |  Quote  |  Print  |  Notify Moderator
Velcro. You may have to silicone something under the bottom of the microwave to get enough flat surface, but, it'll work GREAT.
whjco
Lexington, KY
Posted: 07/14/20 11:58am Link  |  Quote  |  Print  |  Notify Moderator
We had a Starcraft with a Dometic microwave that failed. I replaced it with an LG from Best Buy. I was able to adapt the mounts from the Dometic to work with the LG microwave and it fit like it was factory installed.
Bill J., Lexington, KY
2006 Starcraft 2500RKS 25' Travel Trailer
2015 Ram 2500 Big Horn 6.7 Cummins.
schlep1967
Harrisburg, PA
Posted: 07/14/20 12:08pm Link  |  Quote  |  Print  |  Notify Moderator
I know many have done it and not had problems, but... check where the vents are on your new counter top microwave. Make sure you have proper ventilation for those vents.
2008 Dodge Ram 2500 Diesel
2009 Open Range 385RLS
Pull-Rite Super Glide
CavemanCharlie
Storden,MN
Posted: 07/14/20 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
X2
travisc
Pacific NW
Posted: 07/14/20 10:48pm Link  |  Quote  |  Print  |  Notify Moderator
FPS all right angle brackets work too with sheet metal screws. You can get rv microwaves with kits pretty in expensive online.
Winnebago Access 24V
