RV.Net Open Roads Forum: I need help locating leveling jack pump
 > I need help locating leveling jack pump
OLDROADDOG
AT HOME
Posted: 07/14/20 07:09pm Link  |  Quote  |  Print  |  Notify Moderator
I can't locate the hyd. Oil tank for the leveling Jack's, or the fuse for this pump on my 2008 fleetwood providence.help
near Jawbone Canyon, CA
Posted: 07/14/20 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
Owner's manual is of no help?
See https://www.fleetwoodrv.com/for-owners/support/owners-manuals
MrWizard
Traveling
Posted: 07/14/20 10:50pm Link  |  Quote  |  Print  |  Notify Moderator
Did you Look under the living room slide out
On many RVs one system is used for both slides and jacks
My 97 Bounder the jack pump is curbside up front of the wheel
On the previous RV it was curbside rear
Radiate The Happy
1997 F53 Bounder 36s
Wherever I happen to park
Posted: 07/15/20 04:46am Link  |  Quote  |  Print  |  Notify Moderator
Easiest way may be to do a walk around while a partner operates the jack controls assuming the pump runs.. Follow your ears.
Option 2 is follow your hose.. I'd start with the front jacks. follow the hose from one of the jacks. you MIGHT get lucky. If it runs into who knows where try the rear jacks.
Home is where I park it.
AikenRacer
Aiken, S.C.
Posted: 07/15/20 06:04am Link  |  Quote  |  Print  |  Notify Moderator
Sometimes these things are behind outside panels with no opening handle. I had one a while back on a Thor that I had to remove two bolts on the bottom of the panel to open the panel door. From the exterior, it appears to be a dummy panel. Don't understand why the manufacturers don't put openers on all exterior panels.
2012 Tuscany 42RQ tag
2005 Silverado 2500 w/ piggy back golf cart
wildtoad
Blythewood, SC
Posted: 07/15/20 06:39am Link  |  Quote  |  Print  |  Notify Moderator
Try the front wheel well. My 2000 Hurricane on a Workhorse chassis hat it there.
Tom Wilds
Blythewood, SC
2015 Jeep Wrangler 2dr HT
John Wayne
Long Beach, Ca
Posted: 07/16/20 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
When you find make sure what oil it takes most are trans fluid NOT hyd. oil.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
Branson N Tucson
Tn
Posted: 07/16/20 06:18pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2004 Providence, mine is located on Passenger side of motor home, in the Baggage bin.
The 3rd. One from rear.
