RV.Net Open Roads Forum: Class A Motorhomes: Class A V-10 mileage
 > Class A V-10 mileage
crawford
Dandridge Tenn.
Posted: 07/22/20 01:43pm Link  |  Quote  |  Print  |  Notify Moderator
I have a Saturn as a toad I get 7 even but then with out still the same.
Change from a c class to a A class Georgetown 07 triple slide
hohenwald48
Nashville, TN
Posted: 07/22/20 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
Oddly, running the generator likely won't even change your mileage numbers unless you're calculating to a couple decimal places. It only burns around 1/3 GPH and at 60 MPH you're already burning around 10GPH.
When seconds count, the police are only minutes away.
2015 Open Range 216 RBS
2013 Nissan Armada Platinum
TCmart
Long Island, NY
Posted: 07/30/20 10:48am Link  |  Quote  |  Print  |  Notify Moderator
I average 7 to 7.5 mpg on a 2000 Bounder towing a 2007 Honda Pilot. I normally run the generator and both a/c's while driving.
Tom and Christine
2000 Bounder 34T
Life is Good!
Blackdiamond
So. Cal
Posted: 07/30/20 12:06pm Link  |  Quote  |  Print  |  Notify Moderator
In my old 2002 chassis with the 4 speed, I get 5.5 towing a 5000 lbs trailer, 7.5 when not towing.
03' Fleetwood Southwind 32VS
Enclosed Trailer hauling the toys
05 525 EXC KTM
15' FE350s Husqvarna/KTM
07 Rhino, long travel, 4 seater
tedp
Waunakee, WI
Posted: 09/28/20 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
2013 32' Class C towing a Mini Cooper averaged 8.4 over 2 years driving 6,000 miles per year. No real mountains around where I drove it though!
Chum lee
Albuquerque, NM
Posted: 09/28/20 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
A1ARealtorRick wrote:
So, if well-engineered cars can have 8, 9, and 10-speed automatic transmissions in an effort to maximize fuel economy and enhance overall performance in the process, why can't motorhomes?
Of course they can. Motor homes generally operate at/above/or close to maximum gross weight. Not so with daily drivers. Most motor homes have the aerodynamic efficiency of 3 - 4' x 8' stacked pieces of plywood which they struggle to push through the air at 55 - 75 mph. That's where/why the fuel efficiency goes through the floor. IMO, the number of speeds in the transmission doesn't matter with regard to fuel efficiency. It only makes the driving/towing experience more palatable.
Chum lee
FloridaRosebud
Melbourne
Posted: 09/28/20 06:47pm Link  |  Quote  |  Print  |  Notify Moderator
I just finished a 1400 mile round trip, towing an Acadia. SeaBreezeLX F-53. Got 7.2 mpg....
Al
Gjac
Milford, CT
Posted: 09/29/20 05:34am Link  |  Quote  |  Print  |  Notify Moderator
I have driven the same MH in my signature a little over 100,000 miles and have tracked every fill up over the last 15 years manually. I tow a 2500lb Toyota Corolla most of the time. I don't notice any MPG difference towing vs not towing. Added headers and FF muffler. No difference. Added CAI sans cat. No difference. Advanced base timing from 4 degrees BTC to 9. Slight difference. Each mod improved performance but not MPG. Performance went from 19 sec to go from 40-60 mph down to 12 secs. Went from down shifting at the slightest hill to staying in high gear in all but steep hills out west. There were several things that I observed that increased my MPG slightly. Keeping my speed between 55 on backroads and 62 on the highway increased mpg from 8 to 8.5 . Adding a vacuum gauge and keeping vacuum above 10 in HG. Also increasing speed when approaching a hill then letting off the throttle to keep it in high gear. I know when it will shift by watching the vacuum gauge. This increased my mpg to 8.7 mpg. Having said all that I like the increased performance over the mpg gains.
Dale.Traveling
Newport News, VA
Posted: 09/29/20 07:58am Link  |  Quote  |  Print  |  Notify Moderator
I figure when I have the toad along for the ride, and since it's a fully drivable self powered vehicle, my mileage is double to 15 or so. And since there is usually two of us in the coach I get another double taking the rate up to 30 MPG.
Day dreaming helps pass the time until the next outing.
2006 Hurricane 31D built on a 2006 Ford F53
