RV.Net Open Roads Forum: Anyone use Quick connect for water hose?
 > Anyone use Quick connect for water hose?
agesilaus
North Florida
Posted: 07/17/20 10:05am Link  |  Quote  |  Print  |  Notify Moderator
I've been using these: Amazon We picked them up at a local store tho. We do not have a door over our fittings so we just use the male end on the water fill and tank flush fittings. They have a cap dangling on a short plastic tether than fits right over the end of the male quick connect. I need to order some more so I can put then on our extra hoses. I don't know if these are any better than other brand but they work.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
sgfrye
north carolina
Posted: 07/17/20 11:19am Link  |  Quote  |  Print  |  Notify Moderator
yes money well spent.
kfp673
PA
Posted: 07/17/20 12:14pm Link  |  Quote  |  Print  |  Notify Moderator
Excellent, thanks all! I'll give it a shot!
ernie1
Sacramento,California,USA
Posted: 07/17/20 01:54pm Link  |  Quote  |  Print  |  Notify Moderator
kfp673: Sorry I don't have any links. I completed. my project after numerous runs to different rv parts stores. Sorry.
John Wayne
Long Beach, Ca
Posted: 07/17/20 04:16pm Link  |  Quote  |  Print  |  Notify Moderator
From my experience if you get the brass ones you want the one 's with the rubber washer. The Harbor freight one's will start leaking over time if they are just brass to brass.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
STBRetired
I-80 and I-55
Posted: 07/17/20 04:35pm Link  |  Quote  |  Print  |  Notify Moderator
^^X2 Get the ones with the rubber o-rings. A light coating of silicone grease will keep the o-rings sealing well. Used QDs a lot when we used to take many shorter trips each year. Not so much anymore as we either boondock or stay at our winter location for 6 months.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
Johno02
Lexington, TN USA
Posted: 07/17/20 08:45pm Link  |  Quote  |  Print  |  Notify Moderator
I have QDs on everything. Just easier to hook up and then break down later. Fresh water hose, connect the ends when stored to keep critters out. I also have a water filter that is used occasionally, QDs make it easier to connect however we need at the time. But use the brass ones with o-rings. I carry a couble of spare sets, the ends occasionally get damaged and are hard to use.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
mobeewan
Hampton, Va
Posted: 07/19/20 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
I added quick connect garden hose fittings to my low point drains. I can connect an outdoor sink for outside hot and cold water cleaning or an on demand water heater in lieu of the onboard water heater or a city water in through the cold water low point.
There is a small plastic 90° garden hose elbow quick connect available. It might work for you but hasn't for me on the city water inlet for closing the hatch after disconnecting. I bought them at one of my local trailer dealers. It was only the male hose thd x male garden hose quick connect fitting. Camping World has them as a set. Hose saver with quick connect.
* This post was edited 07/19/20 04:39pm by mobeewan *
down home
south
Posted: 07/20/20 12:22am Link  |  Quote  |  Print  |  Notify Moderator
I use them. However with low pressure if not aligned they may leak. I have some older ones that have tighter tolerances.
Amazon has a variety but I haven't
tried any of them except the ones that look the same as those from CW.
* This post was edited 07/20/20 12:31am by down home *
Housted
Los Angeles, CA
Posted: 07/20/20 10:48am Link  |  Quote  |  Print  |  Notify Moderator
I use these on all my hoses....They are leak free and very secure.
Banjo connector --> https://barndoorag.com/search-results/?search_query_adv=garden+hose+banjo
Housted
2015 Dodge 3500 Laramie 6.7 CTD Tow Rig Integrated ball with Andersen Ultimate 5th Wheel hitch
2011 Arctic Fox 29-5T 5th - 4 Pt Leveling, Disk Brakes, 1050 W Solar,
300 Amps of LiFePO4,3000 Watt Inverter
  • pic
    Too many mods to Truck and trailer to list.
  • Reply to Topic  |  Subscribe  |  Print Topic  |  Post New Topic  |
