RV.Net Open Roads Forum: Class A Motorhomes: Transfer switch popping every 15 seconds
 > Transfer switch popping every 15 seconds
Tmuraca
Ithaca, NY
Posted: 07/18/20 06:51am Link  |  Quote  |  Print  |  Notify Moderator
I’m plugged into a 30 amp pedastal and my transfer switch keeps popping. I checked all the wiring and it looks clean and nothing is loose. I tried unhooking power and running the generator and everything works fine, so this only happens on shore power. At the plug I have a progressive industries surge protector. Could this just be a faulty transfer switch?? Thanks for any help!!
Tmuraca
Ithaca, NY
Posted: 07/18/20 07:11am Link  |  Quote  |  Print  |  Notify Moderator
I should have added that I am in a 2014 Tiffin Allegro 36La and the transfer switch is TRC industries number 41260. I should also note that it will work fine for a few hours before it starts acting up
wolfe10
Posted: 07/18/20 07:28am Link  |  Quote  |  Print  |  Notify Moderator
First thing is to verify that your shore power IS good. What is voltage when this happens as measured in the coach? If below 108 VDC, check at the pedestal. May be CG power issue or issue with your shore power cord or wiring to ATS.
At only one CG of at others?
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
Tmuraca
Ithaca, NY
Posted: 07/18/20 08:02am Link  |  Quote  |  Print  |  Notify Moderator
The voltage is fine and I have tried at 3 different plugs so far. All have been 30 amp so I have been using an adapter to plug my 50 amp surge guard at the pedastal. I am wondering if the surge guard could have gone bad and perhaps I should try plugging it in directly?
rgatijnet1
Posted: 07/18/20 08:35am Link  |  Quote  |  Print  |  Notify Moderator
Transfer switches have been known for the individual wire connections coming loose. Make sure that NOTHING electrical is connected and then take the cover off of the transfer switch and tighten all of the connectors. This may solve your problem.
bob_nestor
murphy
Posted: 07/18/20 09:17am Link  |  Quote  |  Print  |  Notify Moderator
I'd also check the contact switches insidw the transfer switch. Normally a transfer switch is wired such that the default position is to prefer shore power and the contact switches inside are held in that position with springs. But if the contacts have a build-up of patina or they're pitted from arcing they might not make good contact. When this happens the junction can heat up and the switch could open. I'd also check to make sure the springs are still in good shape.
wolfe10
Posted: 07/18/20 10:11am Link  |  Quote  |  Print  |  Notify Moderator
Is voltage still 120 VAC+/- IN THE COACH (not just at the CG outlet) when the clicking occurs OR when the ATS clicks do you loose 120 VAC to the coach?
Yes, surge protectors can fail, just as can ATS's and most other electric devices.
2naEagle
McCalla, AL
Posted: 07/18/20 10:56am Link  |  Quote  |  Print  |  Notify Moderator
Make sure your electrical cord prongs are clean and shiny. Also put some NO-Ox on the prongs. See if that helps.
2020 F350 Limited CCSB SRW
2017 North Point 315RLTS
2021 Jayco Redhawk 24B
MrWizard
Traveling
Posted: 07/18/20 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
Xfr switch "popping"
This is not a circuit breaker exactly what do you mean by popping
50 amp RV
50 amp xfr switch
50 amp ems
30 am service
GG voltage is low
Or
Faulty ems
Does your ems display an error code when this happens
Are you letting the A/C cycle the compressor
Or cycle between two different rooftop A/C's
The start up surge will cause low voltage and the ems will trip, shutting you down
Radiate The Happy
1997 F53 Bounder 36s
Wherever I happen to park
Posted: 07/18/20 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
What do you mean by "Popping" The unit you have contains MOV's and if they get over voltaged they can make like firecrackers (Been there when it happened. long story omitted)
Here are 3 links
Before you call
Trouble Shooting Guide
Brag sheet (Specs add)
Guessing you have either an open neutral or open ground or poor neutral/ground on the park side. Just a guess.
Home is where I park it.
