RV.Net Open Roads Forum: Brands That Can Be Used Off The Truck
 > Brands That Can Be Used Off The Truck
craigandsue
Sioux Falls, SD/Port Aransas, TX
Posted: 07/18/20 04:17pm Link  |  Quote  |  Print  |  Notify Moderator
Thinking of upgrading my truck camper. My present one cannot be used off the truck. Who all makes a truck camper that can be used off the truck?
Craig, Sue, 2 boys
2013 F350 DRW Diesel, 2016 Jayco Northpoint 377RLBH, 05 Alpenlite 1150 Santa Fe
sbryan@vtbryans.com
Vermont
Posted: 07/18/20 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
Just about all newer TCs can be used off the truck - Northstar, Northern Lite, Lance, Bigfoot, Cirrus, etc can all be used off the truck.
Shawn
2013 Ford F350 6.7 CCLB Ruby Red SRW, sway bar, Bilsteins, etc
2007 Cyclone toyhauler, 18,000 GVWR
Northstar Igloo 9.5
https://photos.smugmug.com/photos/i-2J3zF6J/0/M/i-2J3zF6J-M.jpg
US Army retired
jimh425
Western MT
Posted: 07/18/20 04:54pm Link  |  Quote  |  Print  |  Notify Moderator
It’s true that most newer campers can be used off truck, but there have been some holding tank straps that failed for many brands in the past.
I think it would be better to ask the manufacturer once you get close, or do a search once you get a used one/new one in mind to find out.
narcodog
Georgia
Posted: 07/18/20 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
That's a curious statement that I never heard. Can you expound on it?
Kayteg1
California > Nevada
Posted: 07/18/20 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
I can't imagine what would prevent ANY TC from being used alone?
I am 1 of those who had issue with water tank weight separating floor from rest of the camper, but that was also due some water damages.
So it is always good idea to put some support at least on front, where water tank is.
My holding tanks hang on straps no matter if on truck or on jacks.
Geo*Boy
Unknown
Posted: 07/18/20 06:06pm Link  |  Quote  |  Print  |  Notify Moderator
Northstar TC’s can be used off the truck.
KD4UPL
Swoope, VA
Posted: 07/18/20 08:12pm Link  |  Quote  |  Print  |  Notify Moderator
Your saying your Alpenlite can't be used off the truck? I've never heard of such a thing. Is that on a warning label somewhere, in the manual?
I've done a lot of studying on TC over the years and I've owned 2 of them. I've never run across anything that said any of them couldn't be used off the truck.
jimh425
Western MT
Posted: 07/18/20 09:42pm Link  |  Quote  |  Print  |  Notify Moderator
Which part? I’ll take a guess. Btw, if you keep up with the threads and remember the cases, it helps. But, you can also do a search along with “site[emoticon]v.net” which will find cases in the archives.
That’s why I said, don’t assume that the particular model will be fine.
Arctic Fox strap failure
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/21247815/print/true.cfm
Bigfoot failure
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/20086672/print/true.cfm
Popups not recommended off truck.
https://www.rv.net/forum/index.cfm/fuseaction/thread/tid/19120591/print/true.cfm
billtex
RI
Posted: 07/21/20 05:47am Link  |  Quote  |  Print  |  Notify Moderator
I think it’s pretty safe to say most TC’s can be used off the truck. The question may be which ones can be used with full tanks off the truck. A little research with the Mfr should get this information. Our Eagle Cap specifically says in the literature it can be used off the truck with full tanks and we have done so many times.
It is true there have been tanks that have sheared their holding straps. Like anything, once they get old-a little preventive inspection/maintenance is a good idea.
2020 F350 CC LB
Eagle Cap 850
25'Airstream Excella
"Good People Drink Good Beer"-Hunter S Thompson
Geewizard
E. Washington
Posted: 07/21/20 07:08am Link  |  Quote  |  Print  |  Notify Moderator
....snip.....
That's an overly broad statement regarding Popups. I've used my Outfitter "popup" TC many many times off the truck. And I will continue to do so.
2004 Outfitter Apex 8
2014 Toyota Tundra Double Cab
220W solar, MPPT controller, LED lights
Wave 3 Heater
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
