RV.Net Open Roads Forum: Beginning RVing: RV maintenance
 > RV maintenance
someuser001
seattle
Posted: 07/19/20 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
We just got a pre-owned RV that is a couple of years old. It is a 2018 Forest River Sunseeker
But I am not sure what the maintenance schedule on this should be. We will likely be using it every weekend all summer. Normally on a car, it is recommended to get an oil change every 3 months.
What sort of regular maintenance should I be looking at for the RV?
* This post was edited 07/19/20 09:19pm by someuser001 *
Turtle n Peeps
California
Posted: 07/19/20 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
Find out what year and engine you have and we can give you some advice. No such thing as a Ford 350 engine.
outside the fire"
"The best way to get a bad law repealed is to enforce it strictly."- Abraham Lincoln
Lynnmor
Red Lion
Posted: 07/19/20 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
And no such thing as a recommended three month oil change interval on car.
Veebyes
Posted: 07/19/20 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Start from a known base. Oil & filter change plus a thorough inspection of everything that moves & wears out. Linkages, bushings, everything. You don't want to be miles from anywhere & have something fail that could have been avoided with a simple inspection.
2007 Alpenlite 34RLR
theoldwizard1
SE MI
Posted: 07/19/20 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Class C motorhomes built on Ford chassis' should have a front end alignment first. Don't be surprised if it needs parts including shock absorbers. Also have the brakes checked.
As long as the oil is at the full mark, it can wait until fall.
"Extreme usage" usually calls for oil and filter change every 3,000 miles.
wanderingaimlessly
SOBOVA
Posted: 07/19/20 06:36pm Link  |  Quote  |  Print  |  Notify Moderator
You likely mean it's on an E-350 chassis, which is a cutaway van body.
Find out what year of motorhome it is, then look for a Ford E-350 service schedule for the prior year.
You may find this helpful Ford E 350
someuser001
seattle
Posted: 07/19/20 09:20pm Link  |  Quote  |  Print  |  Notify Moderator
Updated with info. It is a 2018 Forest River Sunseeker
someuser001
seattle
Posted: 07/19/20 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
very helpful - thanks
Jebby14
Windsor Ontario
Posted: 07/20/20 04:49am Link  |  Quote  |  Print  |  Notify Moderator
dont forget about the camper half, water intrusion is the death of a camper. lap sealant should be checked a couple times a year and redone as needed. a good roof treatment once a year is nice too
Q: Whats brown and sticky???
A: A Stick....
wanderingaimlessly
SOBOVA
Posted: 07/20/20 07:13am Link  |  Quote  |  Print  |  Notify Moderator
For a complete manual get your VIN from the registration and insert it here. E-350
Complete owners manual, warranty and other info.
Happy motorin
 > RV maintenance
