RV.Net Open Roads Forum: General RVing Issues: ac leak
Jebby14
Windsor Ontario
Posted: 07/20/20 09:24am Link  |  Quote  |  Print  |  Notify Moderator
hey everyone, last time we were out my AC ran A LOT. it leaked inside over night the one night. figured it needed the drip tray cleaned so I did that this weekend. didn't appear to be blocked any and it didn't have the normal pin holes for drainage but a chute to the side.
cleaned it out anyway.
if it starts up again what should I check next?
think its just freezing up? dicore all looked good.
Q: Whats brown and sticky???
A: A Stick....
John Wayne
Long Beach, Ca
Posted: 07/20/20 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
If you use it where you have high humidity run the fan on high to avoid freezing it up (the coils). If you drop the inside panel you should see 4 bolts 1 in each corner. these need to be snug Don't over tighten. The A/C sits on a foam gasket that you don't want to crush this is what keeps the water out from the roof. You should be able to see it when you drop the inside panel. These 4 bolts need to be snugged or checked every once in a while.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
Wherever I happen to park
Posted: 07/20/20 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
When was the last time you cleaned the filters on the inside?
What happens
The fliters clog the blower creates a vacuum in front (And behind) the Condenser that is strong enough to Suck the water out of the drip tray.
Then it drips
Home is where I park it.
theoldwizard1
SE MI
Posted: 07/20/20 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
You need to verify that the drip tray tube is clear.
CavemanCharlie
Storden,MN
Posted: 07/22/20 07:07pm Link  |  Quote  |  Print  |  Notify Moderator
How level was the RV ? If it was leaning to the side opposite of the "Chute" it may have simply overloaded the drip pan because it was working so hard.
beemerphile1
Ohio
Posted: 07/22/20 08:30pm Link  |  Quote  |  Print  |  Notify Moderator
When was the last time you snugged up the four mounting bolts?
2018 Keystone Cougar 26RBS
2006 Weekend Warrior FK1900
Jebby14
Windsor Ontario
Posted: 07/23/20 04:40am Link  |  Quote  |  Print  |  Notify Moderator
drip tray is clear and discharges out both sides (not through little pin holes) though the trailer was level, bolts are snug. it was humid as can be. did a quick clean, will get a more in depth cleaning and a filter change at the end of the season. Thanks all.
