RV.Net Open Roads Forum: Class A Motorhomes: Welding on a 1999 spartan chassis
 > Welding on a 1999 spartan chassis
wvabeer
Evans, West Virginia
Posted: 07/20/20 01:48pm Link  |  Quote  |  Print  |  Notify Moderator
Are there any precautions I should do before welding on my Dutch Star frame?
1999 Dutch Star DP3884
2015 Camplite 6.8C
2013 F150 XL SC 4X4 Ecoboost 6.5
17 Z125
15 PCX 150
MountainAir05
New Mexico
Posted: 07/20/20 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
battery disconnected, both positive and Neg. and cover so they do not touch anything. Any electrical device that is power near where you are welding. Use to have to disconnect Alt and Gen leads also many years ago. Also attach ground clamp for welder as close to welding spot. Sure someone will log in. Maybe Doug or Wolfe
wolfe10
Posted: 07/20/20 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
Your chassis manual should say, but you also need to disconnect any computers, like the Allison ECU. Spartan will have the complete list.
Short answer is that PC boards do not like welding near them.
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
JRscooby
Indepmo
Posted: 07/20/20 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
Clamp ground close, but out of way. Use grinder to be sure clean connection. First arc, tack ground to frame. This will make sure the ground stays good, and the little amps don't go wandering around hunting a better path home.
wvabeer
Posted: 07/21/20 08:10am Link  |  Quote  |  Print  |  Notify Moderator
I am purchasing a used cruiselift motorcycle lift/carrier for my Road king. I need to build a heavy hitch for it. I already have a very heavy duty 10000 lb hitch there but need to add a 2" reciever to each side of it. So welding is needed.
wildmanbaker
Kennewick, Washington
Posted: 07/21/20 09:05am Link  |  Quote  |  Print  |  Notify Moderator
Fire may be a bigger hazard than stray electrons. If you unplug things, make a list and a general location of the plugs for reconnecting. Take pictures, lots of pictures. Dielectric grease is you freind here. Remember, when you plug things back in, they may not come back like they should.
Good luck.
Wildmanbaker
RLS7201
Posted: 07/21/20 10:50am Link  |  Quote  |  Print  |  Notify Moderator
I've stood in Tiffins' Red Bay weld shop and watched them weld on frames without them disconnecting any thing. Get your ground clamp close to the weld area and go for it.
Richard
95 Bounder 32H F53
460/528 stroker
Web Master
MWPSchooners.com
First brake job
1941 Hudson
wildmanbaker
Posted: 07/22/20 10:07am Link  |  Quote  |  Print  |  Notify Moderator
Richard
Exactly, I doutb any manufacture disconnects anything before welding on the chassis. There is too much of a chance of forgetting to reconnect things as the build goes on.
JRscooby
Indepmo
Posted: 07/22/20 10:22am Link  |  Quote  |  Print  |  Notify Moderator
Richard
I have laid under a truck in Gladstone Mo and welded a broken walking beam back together, and never disconnected anything. (walking beam is the part that mounts between axles, the spring mounts to it. Holds up that corner of truck) Told owner to dump load, go home and replace beam.
OTOH, a quick tack to hold a bracket on my old utility trailer burned out every lamp.
wolfe10
Posted: 07/22/20 10:27am Link  |  Quote  |  Print  |  Notify Moderator
Suspect we are seeing a mix of "Best Practices" as well as "What I got away with".
Choose which path you want to follow-- it is your coach/your decision.
