RV.Net Open Roads Forum: Wheels off the ground "Does it Hurt the frame/RV"
 > Wheels off the ground "Does it Hurt the frame/RV"
HighwayJunky
Crestview
Posted: 07/21/20 08:42am Link  |  Quote  |  Print  |  Notify Moderator
We love camping in state parks but sometimes run into short or unlevel campsites. Our MH is 43'ft. For unlevel sites some folks recommend placing blocks under the leveling feet but then we might run into the wheels on the MH raising off the ground. My question: Does this cause any undue stress on the motorhome?
Appreciate your expertise in this matter,
2015 Itasca Ellipse 42QD
2012 Fiat Pop Toad
One wife
No pets
No complaints
No Worries (except keeping wife happy!!)
Fulltime jobhttps://www.rv.net/SharedContent/cfb/images/rolleyes.gif
IB853347201
Eastern Ontario
Posted: 07/21/20 10:33am Link  |  Quote  |  Print  |  Notify Moderator
No issue with having your front wheels off the ground. You should not however use the jacks to lift your rear wheels off the ground as it circumvents your parking brake.
Touring in our 2010 Suncruiser, beaches, site seeing, national parks, chillaxing..
gbopp
The Keystone State
Posted: 07/21/20 11:50am Link  |  Quote  |  Print  |  Notify Moderator
Someone near where I live stored their gas Class A with the front wheels off the ground, using only the jacks, all winter.
Apparently it caused no problems. They did it for several years.
dieseltruckdriver
Black Hills of SD
Posted: 07/21/20 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
First, I do not have and have never had a class A, but, when the rv is in the air on jacks, how could it possibly move. When it is off the ground, there is nothing round that can roll.
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
JimR 1
Custer South Dakota
Posted: 07/21/20 07:58pm Link  |  Quote  |  Print  |  Notify Moderator
I think it could slide. On my MH the jack base is maybe 10 inches of steel as compared to rubber tires on the ground X 2 or 4 seems better to me.
As far as the OP question I do not know but for me I do not like to lift the wheels off the ground, I have done it but.
jimR
DrewE
Vermont
Posted: 07/22/20 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
The front wheels are presumably still on the ground and are free to roll. The only thing preventing it from moving laterally are the jacks, and they're generally not designed to prevent that sort of movement to any large degree (i.e. they, or their mounting, could bend or break under the strain). Securely chocking the front wheels presumably would help prevent trouble, and seems a very good idea under the circumstances in any case.
Yosemitebobr
Washington
Posted: 07/26/20 06:11pm Link  |  Quote  |  Print  |  Notify Moderator
It says I'm the manual to not raise with the wheels off the ground. With that being said, when I rase mine that high I put blocks under the wheels. I have a full slide and it can effect that over time.
By my research the longest Class C is, the Jayco Seneca at 39' 1"
* This post was edited 07/30/20 04:17pm by Yosemitebobr *
YosemiteBobR (Bob)
2015 Thor Four Winds 33SW, Super C diesel
Two Labordoddles one white one brown
My DW the co-pilot/navigator (the boss)">
GROWING OLDER IS MANDATORY, GROWING UP IS OPTIONAL
Chum lee
Albuquerque, NM
Posted: 07/30/20 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
The simple answer is . . . . it depends. It depends on WHERE the jacks are located on the frame. Usually they are ahead of the front wheels and behind the rear wheels. If that is the case on your Class C you are extending the wheelbase when you lift the wheels off the ground. That DOES increase the stress on the frame. Does it hurt the frame? It depends on how much the frame bends. I've seen a 32' Class A pop the windshield out of the fiberglass frame in extreme cases. On a Class C the windshield is part of the base chassis (cab) and built by Ford/Chevrolet/etc. so it is considerably stronger than most Class A gassers. You state
you have a 43' Class C? A Super C?
Chum Lee
memtb
Wyoming
Posted: 08/01/20 09:50am Link  |  Quote  |  Print  |  Notify Moderator
HighwayJunky, It certainly won’t work for us! We have a pretty darn heavy (Bigfoot) class c, on an E-450 chassis. If we try to do a “4 -point” level on very uneven terrain, the frame “flexes” enough that the RV entrance door will bind badly. This can’t be good for the integrity of the RV! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
scbwr
North Ridgeville, OH
Posted: 08/11/20 08:37am Link  |  Quote  |  Print  |  Notify Moderator
1. Follow manufacturer's directions for leveling and whether front wheels can be off the ground. Rear wheels should NEVER be off the ground.
2. Personally, I would always keep the front tires on the ground. I just came back from a trip with our MH and the site was sloped such that I couldn't come close to getting level. I went to Lowes, purchased a 2X10 and cut enough blocks so that I could put blocks under the front levelers and tires.
Just my 2 cents worth!
Safe travels!!
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
