RV.Net Open Roads Forum: Beginning RVing: RV awning cleaning
 > RV awning cleaning
rvshrinker
Beautiful Pacific Northwest
Posted: 07/21/20 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
Based on some other threads and the interwebs, I sprayed my awning with 1 TB each of dish soap and bleach dissolved in one gallon of water. I rolled it up and let it sit for ten minutes, then sprayed it off with a hose and... Nothing! Was not cleaner at all.
So, I ended up hand scrubbing every inch of that blasted awning, all on a ladder with my arms uncomfortably in the air over my head.
I had never washed it in almost three years and it was dirty. But there has to be an easier, and safer way.
If I repeat the spray roll rinse routine more frequently, like twice a year, will it work better? The trailer is under a carport, but we have a damp climate nine months of the year so fog and mist will saturate the awning no matter what is above it.
guidry
Texas Cajun
Posted: 07/21/20 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
i use half bleach half water and roll it up for at least a half hour or more. Unroll it and rinsed it, it just needed a little scrubbing with a RV brush. Came out almost new. And this was after being rolled up for a year with mold and tree leaves.
lots2seeinmyrv
Neither Here nor There
Posted: 07/21/20 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
We use Mr. Clean Magic Eraser and Simple Green.
The eraser gets the black streaks off.
HappyKayakers
Somewhere in the USA
Posted: 07/21/20 05:01pm Link  |  Quote  |  Print  |  Notify Moderator
Use a soft bristle brush on an extensible pole. Relieves a lot of stress on the arms but you'll still get wet.
Joe and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
Campground Tees
kellem
Shenandoah valley,VA
Posted: 07/21/20 05:02pm Link  |  Quote  |  Print  |  Notify Moderator
Idk, awnings are a must but can be a PITA keeping them clean.
I'm trying to limit some effort this year by rubbing the awning down with 303 then rolling up......have to wait and see.
Lynnmor
Red Lion
Posted: 07/21/20 05:33pm Link  |  Quote  |  Print  |  Notify Moderator
Those easy to use by button pushing power awnings are wonderful till you have bad weather or want to clean them. If you ever had a manual awning that pulls to the ground you would know what I mean. Since mine came with the worthless thing, I leave it rolled up.
MitchF150
Puyallup, WA
Posted: 07/21/20 05:40pm Link  |  Quote  |  Print  |  Notify Moderator
"30 Second Outdoor Cleaner" is what I use. Spray it on (I use my garden sprayer), roll up, let it sit for the time it takes to drink a beer and then roll back out and spray it off top and bottom.
Comes out pretty good if you keep up with it. If there is deeper stains and such, I use a car wash brush on a long handle to scrub a little bit more.
Good luck! Mitch
dieseltruckdriver
Black Hills of SD
Posted: 07/21/20 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Good luck! Mitch
Soooo,
It works in like two minutes?
[emoticon]
2000 F-250 7.3 Powerstroke
2018 Arctic Fox 27-5L
ken56
Tennessee
Posted: 07/21/20 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Just did mine today and it was the dirtiest I have ever let it get...meaning bad. I used Awesome, about 4 ounces diluted in a 1 gallon sprayer. Bottle says dilute it 10 to 1 for vinyl. Sprayed it down generously and rolled it up and let it marinate for 15 minutes. Then I filled my car wash bucket with car wash soap and unrolled it and liberally used the car wash water and soft brush to break any dirt loose. Still has some faint dark spots on it but it worked quite well.
2012Coleman
Posted: 07/22/20 06:08am Link  |  Quote  |  Print  |  Notify Moderator
I use Mold Armor on everything that gets moldy - awning, gaskets around cargo doors, propane tank cover. I spray it on and let it sit then rinse - no rolling the awning up, but suppose that doesn't hurt. Walmart, Lowes.
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
