RV.Net Open Roads Forum: Tech Issues: Electrical - smoked up the cabin
 > Electrical - smoked up the cabin
BFL13
Victoria, BC
Posted: 07/23/20 08:09pm Link  |  Quote  |  Print  |  Notify Moderator
Forget the 18v! Your controller will pass "12v" battery voltage to the array once it is connected to the battery. With no battery you are just seeing array voltage with no battery. You seem to have a 12v array with that 18v. Connect the controller to the battery.
Actually, if it is a 12/24 controller, you should first connect it to the battery so the controller knows it is a 12v system or a 24v system and it sets for that, then you connect the solar panel array to the controller. In this case, it might work just connecting. It will not fry. If it doesn't work right, then do it the proper way around, connecting battery first.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
See Profile for House electronics set-up.
Joe417
AL
Posted: 07/23/20 08:27pm Link  |  Quote  |  Print  |  Notify Moderator
My 2 cents worth of experience.
I had smoke from under my sink while on generator about 2 years ago.
Was the AC wiring inside the automatic transfer switch. I posted picture on the forum but didn't find them when I searched.
Over time the wire nuts had loosened and gotten hot or someone may have left them loose.
The heat it generated melted and blackened the wires back about 3 inches from the wire nuts and finally burned one wire open. The switch still worked but the contacts had been too hot so I ended up replacing the switch. I was able to pull enough wire back to cut off the damaged area. Cost was I think $30 or $40.
Joe & Evelyn
BigWapiti
home?
Posted: 07/23/20 09:36pm Link  |  Quote  |  Print  |  Notify Moderator
Thing is, I think I noticed the 18v while the battery was hooked up earlier - didn't think much of it since I was buried and baffled in all the other stuff. Should have caught my eye, didn't. But if that's the case - that the battery *was* hooked up and still showing 18v - that'd be not good, right? I really, really don't want to burn anything else up. :|
I'll keep that in mind for when I do hook everything back up - thanks!!
My truck: 1998 Dodge 2500 diesel, extra cab, long bed
My camper: 2004 Lance Lite 915
BigWapiti
home?
Posted: 07/23/20 09:38pm Link  |  Quote  |  Print  |  Notify Moderator
I'll definitely go in and check those too, thanks!
But you say 'automatic transfer switch' - is that what I'm seeing labeled the Power Controller?? I'm learning all this new RV lingo.. pardon that.
Bobbo
Wherever I park
Posted: 07/24/20 06:56am Link  |  Quote  |  Print  |  Notify Moderator
Since you don't have a built in generator, you don't have an automatic transfer switch.
Bobbo and Lin
BigWapiti
home?
Posted: 07/24/20 09:17am Link  |  Quote  |  Print  |  Notify Moderator
So to test the solar controller - here's what I did - and I'm still a bit concerned.
* Evergreen solar EC-51, 50W solar panel
* Specialty Concepts ACS Solar charge controller
- 18.6v out of solar controller when unhooked from battery
- 13.8v at the battery when unhooked from controller
- covered the solar panels with plywood
- 0.0v coming out of the solar controller (as expected)
- Hooked up controller to battery
- Removed plywood covering panel
- 16.3v at battery
- Quickly recovered panel with plywood.. here I sit.
Too much charge, yes?
If so, I need to somehow disconnect the panel until I get a new controller - the connector is all gooped in up on the roof.
BFL13
Victoria, BC
Posted: 07/24/20 09:48am Link  |  Quote  |  Print  |  Notify Moderator
I used to have one of those controllers. They still had the user's manual on line a couple years ago with its troubleshooting guide.
Yes, your controller is not working right. ISTR the guide says something about bad FETs or whatever. Need to check that.
BFL13
Victoria, BC
Posted: 07/24/20 10:02am Link  |  Quote  |  Print  |  Notify Moderator
http://specialtyconcepts.com/SPECIALTY_CONCEPTS_PDF_FILES/ASC_INSTRUC_MANUAL.PDF
Bench test procedure scroll way down. Was mention above that where RP can damage the ASC.
If you have Option F, it could be cranked too high, but you would have seen that in past operation, I think
BigWapiti
home?
Posted: 07/24/20 11:51am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, and yes, this is the procedure from the manual that I used also to test the panel/controller. So now, I went up on top, ungooped the plug, unplugged it and regooped the hole.
I'm going to try to find an upgrade controller and get something ordered - so the solar panel is out of commission until that's done.
Now I just wish I knew if that was my original problem or one I created.
Thanks a TON for ALL the help! It's been (and still is it seems) quite a ride.
John Wayne
Long Beach, Ca
Posted: 07/24/20 02:37pm Link  |  Quote  |  Print  |  Notify Moderator
Did you check for any burned wires on the truck the charge line from the alternator to the camper battery, etc. If the camper was on the truck when this happened those wires may have been involved also.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
