RV.Net Open Roads Forum: Class A Motorhomes: Koni vs Bilstein
 > Koni vs Bilstein
Gjac
Milford, CT
Posted: 07/25/20 08:41am Link  |  Quote  |  Print  |  Notify Moderator
When I returned from Alaska I needed a lot of front end work and wanted the Bilstein shocks installed. He said he did a lot of MHs with the Bilstein's and fewer with Koni's in the past and customers preferred the softer ride of the Monroe's. So I went with their recommendation. It was a great improvement in ride quality but it was hard to tell how much was do to shocks and how much do to new front coil springs.
FloridaRosebud
Melbourne
Posted: 07/25/20 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
MountainAir05 wrote:
Check your air pressure also. I have found that as tires age, they get stiff and ride harder. Some brands more than others.
Tires are less than 2 years old. I run 80psi on the front and 85psi on the rears based on the weight (actually weighed) of the MH.
Al
MountainAir05
New Mexico
Posted: 07/25/20 03:52pm Link  |  Quote  |  Print  |  Notify Moderator
Al
That where ours are also.
purplekeenah
greensburg, pa
Posted: 07/25/20 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
I had an '03 34' class A gasser on a Workhorse chassis that came with Bilstein's, it road hard! Changed them out with Monroe's with great results. Next rig was a 2007 40' on a Spartan chassis that came with Bilstein's that hit bridge transitions like a sledgehammer, changed out to Koni's and it really smoothed out the jarring hits.
2015 Newmar Dutchstar 4369
2013 Chevy Equinox
BUTCHPHI
Sacramento, CA
Posted: 07/26/20 01:09am Link  |  Quote  |  Print  |  Notify Moderator
Koni FSD's without a doubt. Changed mine over 100000 miles ago. GREATLY reduced the jarring caused by separation joints in the road and greatly reduced the jarring from the smaller holes in the pavement. They are still on my rig and still seem to be doing as good a job as when new.
FloridaRosebud
Melbourne
Posted: 07/26/20 08:19am Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone!! Jusr ordered the Koni's!
Al
scbwr
North Ridgeville, OH
Posted: 07/26/20 10:47am Link  |  Quote  |  Print  |  Notify Moderator
FloridaRosebud wrote:
rgatijnet1 wrote:
My Koni FSD shocks are NOT gas charged so they do not transfer the small bumps, like road joinst, back to the coach as much as my Bilsteens did.
OK, great. That is good to know....the potholes can not be fixed by shocks, but the expansion joints and bridges I was hoping could be, at least somewhat.
Al
It's an interesting article but you do have to keep in mind the article is pretty old. I wish someone would do another test with results for at least one representative diesel pusher and one representative gas motorhome on the F53 chassis. My research showed many more mixed reviews when it comes to Koni vs. Bilstein shocks on a gas motorhome.
2012 Newmar Bay Star 3302
Blue Ox Avail
BrakeBuddy Advantage
2015 Malibu
"Get busy living, or get busy dying."
Andy Dufresne, The Shawshank Redemption
FloridaRosebud
Melbourne
Posted: 07/26/20 03:10pm Link  |  Quote  |  Print  |  Notify Moderator
Al
I guess I'll find out once I get them installed and take the MH out. I'll report back once I've given them the proper workout.
Al
tropical36
Southwest Florida_USA
Posted: 07/27/20 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
OK, it's a 2006 National Seabreeze, F53 chassis. As stated in my last thread, I've got it handling great, however, still rides pretty rough. Was on the NY thruway today, and was a bit rough, then got to I-79 to head south, and though yes, this is way mo'betta. BUT, the closer I got to Pittsburg, the rougher the ride, until about 20 miles north. At that point, the road was hammering us. Doors were coming open, and twice my cruise kicked off. Even slowed down to 55, but still was vicious.
The original owner replaced the OEM shocks 5 years ago with Bilsteins. I recall from racing days the Bilsteins were always "firm". So the question; has anyone replaced the Bilsteins with the 5-way Konis, and was there a significant difference? I'm not looking for the "buy a DP" answer, as we otherwise love the MH and it's going nowhere. So anyone out there done this? If I could get a 20-30% ride improvement I'd do it. I'm just not ready to sink $12k into a liquid suspension upgrade right now.
Thanks in advance!
Al
How much if any, are you over PSI from what your inflation chart says, for each of your axle weights?
Don't think shock brands will turn thing around all that much, either way, although giving my druthers, I'd opt for the Koni's.
"We are often so caught up in our destination that we forget to appreciate the journey."
07 Revolution LE 40E_Spartan MM_06 400HP C9 CAT_Allison 3000.
Dinghy_2010 Jeep Wrangler JKU ISLANDER.
1998 36ft. National Tropi-Cal Chevy Model 6350 (Sold)
FloridaRosebud
Melbourne
Posted: 07/27/20 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks in advance!
Al
I'm spot on, based on the actual weight of my MH. Sometimes I run 5psi over, but the last few days I've been only a couple of psi over.
Al
 > Koni vs Bilstein
