RV.Net Open Roads Forum: Towing: truck/trailer sway
Search only in Towing
Open Roads Forum  >  Towing
 > truck/trailer sway
Page of 6
Posted: 07/26/20 10:25pm Link  |  Quote  |  Print  |  Notify Moderator
Fill up your rear tires and I’d run 40+ in front too. Maybe even 50 and air down if a bit rough.
That will help. Otherwise, you are pulling a big sail. Unless you have a similar basis for comparison, it may just be “normal.”
Rustycamperpants
Sugar Grove, Il.
Posted: 07/27/20 03:04am Link  |  Quote  |  Print  |  Notify Moderator
It sounds to me that more weight needs to be transfered to the front axle. If your steering seems to be "wondering around" and semis give you fits when they pass, tilt your hitch down more to get better weight transfer to the front of youi tow vehicle. .
2009 Ford Expedition EB, 3.73, Equal-i-zer
2015 KZ Sportsman Showstopper 301BH
Hannibal
Tampa Bay Area
Posted: 07/27/20 03:52am Link  |  Quote  |  Print  |  Notify Moderator
I’d recommend increasing tire pressure to the 51psi on the sidewalls for towing. Goodyear HT should be good for highway towing. Looking forward to your CAT scale results.
2020 F250 STX CC SB 7.3L 10spd 3.55 4x4 66 miles
2010 F250 XLT CC SB 5.4L 5spdTS 3.73 107k miles
ex '95 Cummins,'98 12v Cummins,'01.5 Cummins,'03 Cummins; '05 Hemi
2017 Jayco 28RLS TT 32.5'. Reese HP Trunnion 800
teejaywhy
Gilbert, AZ
Posted: 07/28/20 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
Taxman2436 wrote:
allkidd wrote:
Thank you for the quick replies!
Sounds like I need to get some weights of my truck and trailer. If I take my rig to a weight station on the highway will they take these weight measurements for me?
Not a weigh station. You can take it to a CAT scale at Pilot truck stop near you. Costs about $12.00 to weigh and should give you 3 weights, front axle, drive axle and trailer axle(s).
https://learntorv.com/how-to-weigh-a-travel-trailer/
The Yost Outpost
Gilbert, AZ
2007 GMC Sierra Classic 2500HD, Duramax LBZ
2019 Nash 23D
mkirsch
Rochester, NY
Posted: 07/29/20 07:28am Link  |  Quote  |  Print  |  Notify Moderator
You definitely do NOT have sway.
There are not "multiple definitions" for sway. Sway is not a momentary bobble of the trailer hitting uneven road. Sway is not even the effect you feel from a passing bus or semi.
Sway is an ACTUAL loss of control, that you cannot recover from without extraordinary effort. Sway does not cure itself. Sway does not disappear as the distance between you and the semi increases. Sway always gets worse if left uncorrected, never better as time passes. You either hit those trailer brakes or you end up backwards in the ditch.
What you have is an adjustment issue. Perhaps not enough weight on the front axle of the truck. Perhaps your sway bar system is not being used correctly.
Bobbo
Wherever I park
Posted: 07/29/20 08:52am Link  |  Quote  |  Print  |  Notify Moderator
I agree with this post. There is only one definition of "sway." However, there is correct and incorrect usage of the term "sway."
This video shows what "sway" really is.
Trailer Sway Video
Bobbo and Lin
Cummins12V98
on the road
Posted: 07/29/20 09:55am Link  |  Quote  |  Print  |  Notify Moderator
FIRST thing to do is dump the soft stock tires and buy quality "E" rated tires for the truck.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
bikendan
Camano Island, Wash.
Posted: 07/29/20 01:58pm Link  |  Quote  |  Print  |  Notify Moderator
allkidd wrote:
This spring we purchased our first trailer. It is a 28 foot Grey Wolf toy hauler. It weighs about 5000 lbs and we usually carry about another 1000 lbs.
IMHO, you need to take your combo to the scales and not use vague terms like about and around.
What year and model of Grey Wolf do you have? I don't know of any 28ft toyhauler that weighs 5000lbs. And have you weighed the actual loaded tongue weight? What's your truck's payload capacity?
I think you are underestimating your weights.
Dan- Firefighter, Retired">, Shawn- Musician/Entrepreneur">, Zoe- Faithful Golden Retriever(RIP">), 2014 Ford F150 3.5 EcoboostMax Tow pkg, 2016 PrimeTime TracerAIR 255 w/4pt Equalizer and 5 Mtn. bikes and 2 Road bikes
allkidd
Lee's Summit
Posted: 07/29/20 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Busy day at the truck weight station. Listed below are my weights:
With WDS engaged:
Front axle truck 3040
Drive axle 3080
Trailer 4760
Wthout WDS:
Front truck 2680
Drive 3540
Trailer 4640
Truckonly:
5240
I don't have any idea what these numbers mean!
Thanks for the great help!
Bobbo
Wherever I park
Posted: 07/29/20 06:34pm Link  |  Quote  |  Print  |  Notify Moderator
With WDS engaged:
Drive axle 3080
Trailer 4760
Wthout WDS:
Front truck 2680
Drive 3540
Trailer 4640
Truckonly:
5240
We need front axle and rear axle separately on Truck only.
Page of 6
