RV.Net Open Roads Forum: Family Camping: Hello all
Search only in Family Camping
Open Roads Forum  >  Family Camping
 > Hello all
georgeguenther
Posted: 07/26/20 02:48am Link  |  Quote  |  Print  |  Notify Moderator
I just bought a used camper that's in excellent condition, I just have one problem...the water heater. The tank gets hot and every now and then you get a burst of hot water. The guy I bought it from said he had a problem with the check valve on the top. I replaced the check valve today and it's still just giving me a burst of hot water when I turn it on the goes back to cold. Any help would be greatly appreciated! Thank you.
2112
Posted: 07/26/20 03:53am Link  |  Quote  |  Print  |  Notify Moderator
Perhaps the bypass valve is open. Different builders use different valves but this pic may help. Assure the center valve is closed
2013 KZ Durango 2857
garyemunson
Reno, Nevada
Posted: 07/26/20 06:34am Link  |  Quote  |  Print  |  Notify Moderator
Are you sure the outside shower (or inside) doesn't have the valves open but the showerhead closed? That is a frequent issue that "short circuits" the hot water.
mtdew999
Backwoods, Oregon
Posted: 07/29/20 05:26pm Link  |  Quote  |  Print  |  Notify Moderator
OTOH It's not a hard part to switch out, this grandma has put in a new water heater.
 > Hello all
