RV.Net Open Roads Forum: Add water to class A while boon docking
 > Add water to class A while boon docking
Gdlow
Meridian Idaho
Posted: 07/26/20 09:46am Link  |  Quote  |  Print  |  Notify Moderator
For some reason the onboard pump works to transport water inside the coach, but won't when trying to use the suction port to fill the water tank from a non pressurized system. Anything I could check to troubleshoot? I maybe doing it wrong...been known to happen[emoticon]
Scondly, If I use a portable pump attached to a drill will this fill the tank if set on tank fill on the service panel?
Inquiring mind needs to know...thanks
Gary And Cathy
'05 Dolphin 5342
Honda Element following us ">
Pacnats
GS, FMCA
"> Rallys attended
FMCA Albany, Or.'06
FMCA Redmond, Or.'07
FMCA Quartzite, Az. '10...but not again">
Good Sams "The Rally" Redmond Or. '11
FMCA Redmond August 2014
FMCA Indio, Ca 2013
gbopp
The Keystone State
Posted: 07/26/20 10:15am Link  |  Quote  |  Print  |  Notify Moderator
I didn't realize some RV's had suction ports to draw in water.
Don't you have a regular gravity fill where you use a hose to fill the FW tank? That would work with a drill powered pump.
Sjm9911
New Jersey
Posted: 07/26/20 10:23am Link  |  Quote  |  Print  |  Notify Moderator
You might need to go to the manual. While i dont have a rv, my TT dosent have a gravity fill. You need to set the knobs in a certian way on the pump to get the suction to work. On mine it's the same as when i wimterize it. Good luck.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
opnspaces
San Diego Ca
Are you talking about a short open stub tee'd into the tubing between the tank and pump? If so that suction line is for pumping RV antifreeze through the system when winterizing.
Take a cup of water and stick the suction line in it. Then have somebody turn on a faucet and see if the water gets sucked out of the cup.
2005 Jayco Jay Flight 27BH
1986 Coleman Columbia Popup.
Sjm9911
New Jersey
Posted: 07/26/20 10:29am Link  |  Quote  |  Print  |  Notify Moderator
Just fyi, i was thinking of getting a small battery drill pump or dc water pump to hook up to the city water hook up. Or even add a gravity fill to the tank. But then decided i dont do it often enough to warent that.
MountainAir05
New Mexico
Posted: 07/26/20 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
Yes it will suck water from a say 5 gal can to your tank. Have done it in the past when we had a tank issue and needed to get water back in the system but no city pressure line.
Tal/IL
Central Illinois
Posted: 07/26/20 12:39pm Link  |  Quote  |  Print  |  Notify Moderator
That suction tube is designed to pump anti-freeze into the camper water lines. I don't think it will fill the tank. You could probably pump from a container directly to the faucets.
35 miles from Normal, IL. As close to normal as I'll ever be.
2006 Country Coach Inspire Genoa 40ft
Sjm9911
New Jersey
Posted: 07/26/20 02:05pm Link  |  Quote  |  Print  |  Notify Moderator
On mine it was designed from the factory like that. For both the antifreeze and filling up the water tank when you didn't have a city water hook up. Theres could be simmiler. All it does is change the input and out put of the water pump. But as said 5 gallon cans , so slow. And i only have a TT.
STBRetired
I-80 and I-55
Posted: 07/26/20 02:44pm Link  |  Quote  |  Print  |  Notify Moderator
On my Newmar, if I set the selector in the wet bay to "fill tanks" and the valves in the pump bay to "winterize", it will suck water from the external non-pressurized source and fill the tank. Takes FOREVER to fill 50 gallons this way. Think the drill driven pump would probably be faster.
1999 Newmar MACA 3796 F53 6.8L
2016 Ford Edge Sport
Roadmaster Sterling A/T with Brake Buddy Select
Wherever I happen to park
Posted: 07/26/20 03:03pm Link  |  Quote  |  Print  |  Notify Moderator
The suction port (if you have owe) if for pink stuff in the winter.. Often there is no path from the on-board pump to the tank (easily fixed but can cause issues later)
Suggest a 2nd pump for the transfer. Several kinds out there or you can just use another RV pump not that expensive.
Home is where I park it.
