RV.Net Open Roads Forum: Add water to class A while boon docking
 > Add water to class A while boon docking
Dutch_12078
Winters south, summers north
Posted: 07/26/20 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
On our current and previous motorhomes, the way to suction fill the water tank is to set the valves just as you would for winterizing from a jug, except set the "City/Fill" valve to "Fill" instead of "City".
Dutch
2001 GBM Landau 34' Class A
Gdlow
Meridian Idaho
Posted: 07/27/20 08:04am Link  |  Quote  |  Print  |  Notify Moderator
gbopp wrote:
I didn't realize some RV's had suction ports to draw in water.
Don't you have a regular gravity fill where you use a hose to fill the FW tank? That would work with a drill powered pump.
Nope...No gravity fill.
Gary And Cathy
'05 Dolphin 5342
Honda Element following us ">
Pacnats
GS, FMCA
"> Rallys attended
FMCA Albany, Or.'06
FMCA Redmond, Or.'07
FMCA Quartzite, Az. '10...but not again">
Good Sams "The Rally" Redmond Or. '11
FMCA Redmond August 2014
FMCA Indio, Ca 2013
Gdlow
Meridian Idaho
Posted: 07/27/20 08:06am Link  |  Quote  |  Print  |  Notify Moderator
MountainAir05 wrote:
Yes it will suck water from a say 5 gal can to your tank. Have done it in the past when we had a tank issue and needed to get water back in the system but no city pressure line.
thanks...I will try this
Gdlow
Meridian Idaho
Posted: 07/27/20 08:09am Link  |  Quote  |  Print  |  Notify Moderator
wa8yxm wrote:
The suction port (if you have owe) if for pink stuff in the winter.. Often there is no path from the on-board pump to the tank (easily fixed but can cause issues later)
Suggest a 2nd pump for the transfer. Several kinds out there or you can just use another RV pump not that expensive.
thanks...I will try a small one...as I don't boondockl often
Gdlow
Meridian Idaho
Posted: 07/27/20 08:11am Link  |  Quote  |  Print  |  Notify Moderator
I will check this out...again..I have done it before years ago...but memory is not as good...[emoticon]
bigred1cav
ohio
Posted: 07/27/20 09:01am Link  |  Quote  |  Print  |  Notify Moderator
If you are running out of water in your potable water tank, where are you disposing of your waste water?
Gdlow
Meridian Idaho
Posted: 07/27/20 10:05am Link  |  Quote  |  Print  |  Notify Moderator
Ihave always had a siphoning effect while driving down the road, so depending on distance and starting with a full tank, I end up losing anywhere from 1/3 to 1/2 tank...so need to fill when we get there and be there for a few days...
Bill.Satellite
Full-timer
Posted: 07/28/20 05:23am Link  |  Quote  |  Print  |  Notify Moderator
It seems like it would be a lot easier to fix the siphoning issue!
What I post is my 2 cents and nothing more. Please don't read anything into my post that's not there. If you disagree, that's OK.
Can't we all just get along?
richclover
WY
Posted: 07/28/20 06:34am Link  |  Quote  |  Print  |  Notify Moderator
No gravity fill on my new 5’er either. With 40 gallons useable I needed a way to add more.
I cut an older 25-ft hose in half, added fittings from Ace Hardware, found a 12-v pump on Amazon and added a length of wiring and a plug that fits the solar panel plug. Hooked up to the city water input, with valves set correctly, it’ll transfer a 6-gl jug to the tank in a couple of minutes.
I’m wondering where you’re losing your water?
Rich
2018 Ram 4X4 2500HD Cummins
2020 Chaparral 336TSIK
2019 RAM 1500 Classic 4X4 Hemi
2019 CanAm Maverick Sport 1000
SW WY
gvisnic
Littleton Co
Posted: 07/28/20 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
I use a 12v marine pump. I wired a switch to turn on and off and wires clip onto my 12v house batteries. Run a short piece of hose into 5 gallon container and regular water hose to fill location switch to fill tank or connect to city water. Takes just a couple minutes to put in 5 gallons. Just used this week
