RV.Net Open Roads Forum: Class A Motorhomes: House Batteries
jkc306
95901
Posted: 07/26/20 10:10am Link  |  Quote  |  Print  |  Notify Moderator
Have 2017 Thor ACE, battery dead, jumped started and let run for about an hour. Unplugged from 30amp electrical while in RV barn. Few days later went out to Thor and discovered house batteries are dead...Pretty sure they are "new" still and should be working. Any insights would be helpful (New to RVing)
John Contreras
Thermoguy
Graham, WA
Posted: 07/26/20 10:11am Link  |  Quote  |  Print  |  Notify Moderator
Take the battery out and have it tested - I believe Batteries plus will do this for you.
Johno02
Lexington, TN USA
Posted: 07/26/20 10:13am Link  |  Quote  |  Print  |  Notify Moderator
Have had the same thing several times. In your and most rigs, there is enough draw on the batteries to run them down in a couple of days. CO detector, maybe a light left on, whatever... It will happen. If you have a battery disconnnect, use that when leaving it for any period without power on.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and a grouchy, old, tiny dog
theoldwizard1
SE MI
Posted: 07/26/20 10:31am Link  |  Quote  |  Print  |  Notify Moderator
If your batteries are "dead" (<10V) and have been sitting that way for mor than a day, don't waste your time trying to recharge them. Buy new ones.
Every RV owners should have a multi-meter with a built in "amp-clamp". While these are not prefect meters, even the cheap ones will register a draw of over 100Ma (0.100A). Anything over about 10mA when you think everything is OFF will run a battery down.
Decent one (you can spend a lot more for one also) Uni-T UT210E Current Mini Clamp - Amazon $50
Mono Basin National Forest Scenic Area
Posted: 07/26/20 10:34am Link  |  Quote  |  Print  |  Notify Moderator
If your batteries are “dead,” they are not still usable.
wanderingaimlessly
SOBOVA
Posted: 07/26/20 10:37am Link  |  Quote  |  Print  |  Notify Moderator
Since your talking about the chassis battery, A 2017 motorhome was likely sold in 2016 or at least the battery was placed then. So it's likely nearing the end of it's life.
Any auto parts store can test and recommend a suitable replacement.
CA Traveler
The Western States
Posted: 07/26/20 10:40am Link  |  Quote  |  Print  |  Notify Moderator
Have the battery load tested - most auto stores for free. New batteries fail or they are abused.
I installed a battery disconnect switch on the battery post on both banks so that every thing is disconnected. I also fully charge the batteries every month even though they will be OK for many months disconnected.
2014 Grand Cherokee Overland
Bob
time2roll
Posted: 07/26/20 10:42am Link  |  Quote  |  Print  |  Notify Moderator
Maybe the disconnect was left in the in-use position and they discharged?
Plug back in and check battery voltage. You should see 13.6+ volts within an hour. Watch for excessive gassing or heat that would indicate an internal short. I assume you have proper water levels in the battery.
675w Solar pictures back up
dougrainer
Carrolton, Texas
Posted: 07/26/20 12:23pm Link  |  Quote  |  Print  |  Notify Moderator
1 Hour of running is NOT going to fully charge your dead batteries. Doug
pianotuna
Regina, SK, Canada
Posted: 07/26/20 12:53pm Link  |  Quote  |  Print  |  Notify Moderator
Consider a better way to maintain the batteries.
If these are toast, consider SiO2 chemistry. It costs more initially--but has a lower cost per cycle. They can survive an occasional total discharge (not recommended).
Regards, Don
