RV.Net Open Roads Forum: AC problem from hell: Now compressor is turning off.
 > AC problem from hell: Now compressor is turning off.
Cheapfix
Oregon
Posted: 07/27/20 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
Doug, btw, I closed up over half an hour ago and the compressor is still running. Interior is cool. I'm tempted to let it run 24/7 until I have a better grasp on what the problem might be. That assumes it keeps working which it may not. Thanks, Bill
Cheapfix
Oregon
Posted: 07/27/20 09:28pm Link  |  Quote  |  Print  |  Notify Moderator
Doug, btw, I closed up over half an hour ago and the compressor is still running. Interior is cool. Back of the unit is super hot. Pipe going to the front is ice cold. I'm tempted to let it run 24/7 until I have a better grasp on what the problem might be. That assumes it keeps working which it may not. Thanks, Bill
cavie
Posted: 07/27/20 10:44pm Link  |  Quote  |  Print  |  Notify Moderator
As a 50 year Master electrician my advice to you is keep your hands off things you know nothing about. In your first post you stated " I replaced the motor, fan blower and compressor". "Replaced a blower motor that wasn't the right one but made do". Scrape that junk off the roof and have someone else install a new one. A/C service work is not a DIY project. As stated above, RV A/C's are not serviceable like a home unit is.
Mont G&J
Missoula, MT
Posted: 07/27/20 11:13pm Link  |  Quote  |  Print  |  Notify Moderator
My Coleman AC has a low voltage cutoff if the campground voltage drops below 109 Volts.
Cheapfix
Oregon
Posted: 07/28/20 12:58am Link  |  Quote  |  Print  |  Notify Moderator
Cavie,
If you don't want to be of help, please feel free to not barge in and tell off someone you don't know. Here's the link for the motor:
https://www.amazon.com/2-Speed-Air-Conditioner-Motor-Replaces/dp/B07PPT5Y7P
Says it replaces the Fasco. It's not an exact replacement though. They didn't say that. The bolts that attach to the bracket weren't exactly right for one thing. I hope it's okay with you that I drilled four holes.
I'm a long time member of this community. But my old email address no longer works. I signed up for a new account to save time. That's one hell of a way to treat what looks like a new member. I'm glad you have so much knowledge and experience in one area. It may surprise you that most people have areas of expertise. It would be nice if you could share some of what you've got. My guess is you already know what the problem is. If you don't, all you need is a little more info. Oh well, someone else will help.
Anyone want to jump in and help me solve this mystery? The AC is still working perfectly since my last report. I'm going to leave it on and see if it maintains a comfortable room temperature overnight.
If I made any typos, or autocorrect put in the wrong word, please forgive me and/or Google. I swear I'm not the idiot Cavie would make me out to be. I can probably fix this with a little help. If not, I'll use what I learn to hire someone who can. While there isn't nearby RV repair in this rural area. There's easily 20 people in this valley that can fix it. I just need to find one.
Cheapfix
Oregon
Posted: 07/28/20 01:08am Link  |  Quote  |  Print  |  Notify Moderator
Hey Montana, that's good info. Our irrigation pump would not turn on today. Really weird because it's relatively new and rebuilt by the best shop in the state. PUD is working nearby. Ranger comes out tomorrow to look at the pump. If it suddenly works, maybe you're onto something.
Wherever I happen to park
Posted: 07/28/20 04:46am Link  |  Quote  |  Print  |  Notify Moderator
WHere did he say he replaced the compressor? (I reread the origial post several times)
WHen I replaced the blower motor with an other than exact replacement. Well the Expert was on the roof with me it was a combined knowledge effort That's about 600 pounds of beef on the roof [emoticon] (we are both big guys) Worked well till the rest of the unit failed.
Home is where I park it.
Lynnmor
Red Lion
Posted: 07/28/20 05:38am Link  |  Quote  |  Print  |  Notify Moderator
Always check the voltage first thing.
dougrainer
Carrolton, Texas
Posted: 07/28/20 07:33am Link  |  Quote  |  Print  |  Notify Moderator
He DID state Compressor replaced. But on his edit he change Compressor to CAPACITOR. No Big deal but it skews the diag help. Doug
dougrainer
Carrolton, Texas
Posted: 07/28/20 07:36am Link  |  Quote  |  Print  |  Notify Moderator
The ONLY thing you can do at this point is, have a AMP reading of the Compressor. THAT will tell you what is going ON. Since your unit is 15 years old, I would lean to the Compressor OVERLOAD switch is kicking out due to HI amp draw(Bad Compressor). The normal compressor amp draw is around 10.5 to 12.0 amps, depending on the unit. Since your unit is 15 years old, I would replace the upper unit. Stop trying to make a old horse win the race. Doug
