RV.Net Open Roads Forum: Tow Vehicles: Tire choice
Search only in Tow Vehicles
 > Tire choice
IdaD
Idaho
Posted: 07/28/20 11:19am Link  |  Quote  |  Print  |  Notify Moderator
I've been extremely happy with the Falken Wildpeak AT3W I put on my truck last fall. So far they seem to be wearing well and they've performed very well on and off road as well as in winter conditions. They're a better tire than the BFG AT/KO2's they replaced.
If you run your tires at 80 you're going to get a rough ride. I generally drop my rears down to about 60 when I'm not towing or hauling something heavy.
2015 Cummins Ram 4wd CC/SB
APT
SE Michigan
Posted: 07/28/20 12:03pm Link  |  Quote  |  Print  |  Notify Moderator
I think you will will notice a big difference when lightly loaded/non-towing if your pressure is about 60psi all around. Your tire model will make far less difference on stiffness than pressure.
2017 Subaru Outback 3.6R
blt2ski
Kirkland, Wa
Posted: 07/28/20 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
You might even be able to run as little as 40-50 lbs in the rear. Wieght what your rear wieghs empty, pressure up tires accordingly.
I've run many tread designs on rears of trucks, ride quality is based on correct psi for load.
I currently have Cooper ATP3, son just put a second set on his now lifted GM 1500. I've had very few issues running Cooper's since late 80s. A popular M brand.....only XDE M+S in a 19.5 on dump truck are worth the $$$, first born, arm, leg and ALL the money in my pocket!
Marty
Check RV.Net Blogs at: blog.rv.net
monkey44
Cape Cod, MA and Central Fla
Posted: 07/29/20 06:02am Link  |  Quote  |  Print  |  Notify Moderator
Be careful running too low on HD "E" tires, if you do, the sidewalls might crack and come apart while driving. I run mine at 65 empty and 75 hauling the TC. That seems to work fine, and I get a nice ride at both pressures. My truck wears BFG 285/70 "E" shoes ... [emoticon]
Monkey44
Cape Cod Ma & Central Fla
Chevy 2500HD 4x4 DC-SB
2008 Lance 845
Back-country camping fanatic
Bob E.
Canonsburg, PA
Posted: 07/29/20 07:04am Link  |  Quote  |  Print  |  Notify Moderator
I have Firestone TransForce AT's on my truck ('13 Ram 2500) and most of my driving is just running around empty. So I drop rear pressures down to about 50psi. When I'm loaded or towing the camper, I up the pressures to 80psi per the sidewall max pressure. I'm on my 3rd set and got 50,000miles out of each of the first two sets (which is why I keep buying them)...and probably could have squeezed a bit more but snow was coming.
Cummins12V98
on the road
Posted: 07/29/20 09:42am Link  |  Quote  |  Print  |  Notify Moderator
"Be careful running too low on HD "E" tires, if you do, the sidewalls might crack and come apart while driving."
35psi is the lowest pressure listed on the stock "E" tires on my 15 DRW RAM. If you think 35psi "might" cause sidewall cracking please show examples of this.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
cummins2014
Utah
Posted: 07/29/20 09:53am Link  |  Quote  |  Print  |  Notify Moderator
Not sure how low you mean ,I run mine 45-50 psi when empty. You may be referring to Michelins ,they don't need low pressure to cause cracking, they can do that all on their own .[emoticon]
Cummins12V98
on the road
Posted: 07/29/20 09:57am Link  |  Quote  |  Print  |  Notify Moderator
I can document around one million Michelin miles with ZERO cracking running 35-80 psi. YES I do run HOT weather as in AZ and SoCal.
cummins2014
Utah
Posted: 07/29/20 09:58am Link  |  Quote  |  Print  |  Notify Moderator
I had the OE Firestone Transforce HT's ,and I didn't get 30 K out of them on my 2014 Ram 3500. rotated every 5K . Many reports of terrible mileage out of the Firestone Transforce. You must have the touch [emoticon]
cummins2014
Utah
Posted: 07/29/20 10:49am Link  |  Quote  |  Print  |  Notify Moderator
Any doubt about Michelin tires cracking in the sidewall, just google Michelin sidewall cracking, and you will have more reading then you will care to read. I didn't need 20K to find out on a couple sets of Michelin tires . I didn't learn my lesson on the first set [emoticon].
 > Tire choice
