RV.Net Open Roads Forum: Travel Trailers: Recommend a TT (rough roads, no campgrounds)
 > Recommend a TT (rough roads, no campgrounds)
Page of 5
camperdave
northern, California
Posted: 07/28/20 12:35pm Link  |  Quote  |  Print  |  Notify Moderator
I'd focus in on a good strong steel chassis with wood framing/aluminum siding. When it gets whacked into a tree, aluminum dents instead of cracking. Our old Fleetwood Terry was 24' tip to tail and sat nice and high. Needed to convert the dinette to sleep 6 though. Not exactly rough country ready just due to sheer size, but it was surprisingly tough. I bounced it down dumb roads and never did anything worse than ripping up some plumbing. Keep in mind though, it's still a large trailer. You aren't going Jeep trailing with it, some light fire roads at best. It's just too wide and tall for anything more than that.
You could pick up a nice short dual axle wood framed trailer from the 90's for very cheap, then build it out. At least then you start with a good steel chassis and water tanks already in place, and you could build the interior to suit.
2004 Fleetwood Tioga 29v
Thermoguy
Graham, WA
Posted: 07/28/20 01:56pm Link  |  Quote  |  Print  |  Notify Moderator
This might be just over your budget, but should get you anywhere you want to go...
https://newatlas.com/automotive/unicat-md56c-6x6-motorhome/
ttavasc
Western Washington
Posted: 07/28/20 04:52pm Link  |  Quote  |  Print  |  Notify Moderator
24ft box is still going to be overall around 28ft. Our ORV 23DBS is 27'9" but would cover all the items listed. ORV also has the smaller 21DBS that comes in at 25'9" overall - no outdoor kitchen though.
TT: 2019 ORV Timber Ridge 23DBS, Blue Ox SwayPro 15K/1500
TV: 2019 F-250 XLT SuperCab LB, 6.2L, 4.30/e-locker, 164" WB, 4x4
TV - 2014 RAM 1500 Big Horn CC (Traded In)
TT - 2015 Jayco Jay Flight SLX 195RB Baja Edition, Andersen No-Sway hitch (Traded in)
campigloo
Baton Rouge, La
Posted: 07/29/20 03:31pm Link  |  Quote  |  Print  |  Notify Moderator
This won’t completely fill your order but airing the tires down helps a lot. Of course just be sure you can air up before you get back on the real road.
ajriding
st clair
Posted: 07/29/20 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
I have a cargo camper. Learned a lot.
I lifted the body 10 inches by removing the 4 inch drop axle and put a straight axle on and mounting the springs on top of the axle. This gives me more clearance than the truck has and I have never dragged the trailer, came close but havent yet, and if it does no biggie to drag a little bit.
sleeping 6 is a big order, and I bet a temporary situation. Make it for 3 or 4 and have the other 2 or 3 able to fit, but not build that part in.
You could, if money no object, put a roof-top tent up there and that'll add 2-3 more sleepers.
This removes and sells as used when you no longer have 6.
I'm all for converting a cargo trailer. This is by far my favorite of the 6 motorhomes or campers or truck campers that I have owned. Simple, rugged, stealthy, useful and custom built for me.
trail-explorer
NM
Posted: 07/30/20 02:54pm Link  |  Quote  |  Print  |  Notify Moderator
zeke.b.campin wrote:
Looking for suggestions for a new TT. A few years back, we owned a unit from Outdoors RV. It seemed well built but was too large for the places we like to camp. We camp as far in the back country that we can in CO/WY/MT.
-24ish feet box
24' of box length seems really long to be dragging way up into the hills on unimproved dirt fire roads.
Bob
campigloo
Baton Rouge, La
Posted: 08/01/20 08:43am Link  |  Quote  |  Print  |  Notify Moderator
-24ish feet box
That’s true on some roads but I get my 36’ down a bunch of them. It’s often easier than it appears at first.
Posted: 08/01/20 10:24am Link  |  Quote  |  Print  |  Notify Moderator
So why not get another Outdoors RV if you liked it? They make shorter lengths.
However, despite the “cargo trailer conversion” thread, if you’re really intending to get as far back on bad roads as possible, a heavy duty cargo trailer with a lift, or a deck over like a snowmobile trailer is a more rugged platform than most TTs.
2017 Heartland Torque T29
Kach
WA
Posted: 08/01/20 04:09pm Link  |  Quote  |  Print  |  Notify Moderator
We were basically in the same dilemma you are. Family of 5, preferring dry camping in semi rough locations (I usually don’t set out for it to be as rough as it ends up).
We ended up with another basic stick-and tin trailer (Open Range). Anything much better seemed to cost 2-3 times (seriously..) as much. I bought my trailer with the mindset that we’ll mod it to meet our needs.
I was going to lift it, but now that we’ve had it out I think I’m just going to increase the tire size and put airbags on my Tindra to get back those few inches of hitch area clearance.
Long story short, I’ve wedged the trailer into spots as tight as pretty much possible. Most forest service roads were built with logging trucks in mind, so it’s usually not as bad as you think. BLM type roads can vary wildly so you kind of need to know what you’re getting into. On-x maps and Google earth help a lot with the overheads.
* This post was edited 08/01/20 09:33pm by Kach *
Blazing Zippers
North Idaho
Posted: 08/01/20 10:31pm Link  |  Quote  |  Print  |  Notify Moderator
Cocktails for 6
Dinner for 4
Sleeping for 2
The afore was on a placard aboard a vessel and we've found it to be valuable. Especially when we found 6 of us crammed into a small cabover camper due to rain.
Page of 5
