RV.Net Open Roads Forum: Fifth-Wheels: Acceptable electrical load
 > Acceptable electrical load
Rvdude22
Odessa
Posted: 07/28/20 08:03am Link  |  Quote  |  Print  |  Notify Moderator
Good afternoon I have recently purchased a 2007 Keystone Cougar 289BHS. I am new to the world of RVs. With this in mind me and my wife are going to be living in the Rv full time. We do not plan on moving the rv for awhile since we have nothing big enough to pull it with. The RV is a 50 amp with a single ac at the moment I am planning on adding a second to help cool the rv. We are needing extra fridge and freezer space which we are planning on running a 4.5 cubic ft in the area where the bunk beds are and 5.3 cubic ft deep freezer that will sit out side. We also want to use a portable washer. The only other electronics that will be used is normal stuff that would be used for entertainment. With all of this information for what I am drawing for power. Will I need to do anything special to prevent electrical damage to anything in the rv? Also what are some tips that I should look for or do while living in the rv? Thank you anything is appreciated.
* This post was edited 07/28/20 08:25am by Rvdude22 *
jkwilson
Indiana
Posted: 07/28/20 08:23am Link  |  Quote  |  Print  |  Notify Moderator
Not likely. 50A RV service is 120/240V which means you have two 50A 120V circuits giving you 12,000W available. That assumes the circuit supplying power can deliver that.
If you don’t have an easily available, weathertight GFCI outlet on the outside of the RV, you may want to supply the outside freezer from a protected GFCI outlet at the power source.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
enblethen
Moses Lake, WA
Posted: 07/28/20 08:33am Link  |  Quote  |  Print  |  Notify Moderator
Look into feeding the washer and extra refer/freezer from the rig's power source and not run it through the rig's system.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
TXiceman
Full Time RVer
Posted: 07/28/20 08:34am Link  |  Quote  |  Print  |  Notify Moderator
To determine the power draw, all you do is add up the amps. Normally on a 50 amp RV the load is split or balanced between the two 50 amp legs. The A/C's are on different legs and a microwave would be on one leg with an A/C.
If you are plugging these into the RV, you need to determine which leg the plugs are on so that you do not overload one leg.
You may want to run a separate cord to the pedestal to power one of the units.
You may not be allowed to set one of your units outside. Many parks will not allow you to set appliances outside,
Ken
Amateur Radio Operator.
BB_TX
McKinney, Texas
Posted: 07/28/20 08:35am Link  |  Quote  |  Print  |  Notify Moderator
All the electrical circuits are circuit breaker protected with the appropriate amp rating for the wiring to those circuits. And you have a main 50 amp circuit breaker for the incoming power. And, of course, there is the park power pedestal 50 amp breaker. If you exceed the amp rating of any of these that circuit breaker will trip before damage is done.
If you add devices and it trips one of your circuit breakers then you will know that there is too much running off that breaker. The you can try another circuit. If your breaker panel has spare slots, you might add a new breaker and run new wires to new outlet(s). And the 50 amp park pedestal almost always has a standard 20 amp 120 vac outlet. Use that with a good extension cord to run the outdoor freezer.
time2roll
Posted: 07/28/20 08:36am Link  |  Quote  |  Print  |  Notify Moderator
With a 50 amp RV you should not have any issues. Although you may want to check voltage is good (108+) in the hot afternoon when all the neighbors are running air conditioning.
675w Solar pictures back up
GordonThree
Northern Michigan
Posted: 07/28/20 08:37am Link  |  Quote  |  Print  |  Notify Moderator
Only problem I could see you running into is weight issues, two large freezers loaded up, how many pounds is that?
Otherwise, can the park provide adequate amperage service? I've seen low voltage fairly often at busy parks. Low voltage is an equipment killer.
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
Flute Man
Payson, Arizona
Posted: 07/28/20 09:31am Link  |  Quote  |  Print  |  Notify Moderator
I would recommend getting an energy management system from progressive industries. It monitors the power at the pedestal and if anything happens high-voltage etc. because of some fault in the underground cabling The Progressive Industries unit will cut the power to your trailer. Get the best one that you can find. It is cheap insurance compared to the appliances that could be damaged if there is a fault in the pedestal.
I do not repeat do not recommend your freezers be on a GFCI circuit. They are very sensitive units and if it would trip your freezer would shut off.
You may call me if you wish and we can talk about a lot of other things as well.
Jerry Parr
05 Mandalay 40B
Cat C7 350
04 Honda CR-V
Ham Radio K7OU
Retired EE
Jrparr32@gmail.com
602-321-8141
Full-timer
theoldwizard1
SE MI
Posted: 07/28/20 09:32am Link  |  Quote  |  Print  |  Notify Moderator
Just make sure the A/C units are on different "legs" of the 240V feed.
Before you pull the trigger, you might want to consider installing a mini-split heat pump with dual ceiling cassettes.
pianotuna
Regina, SK, Canada
Posted: 07/28/20 10:31am Link  |  Quote  |  Print  |  Notify Moderator
Add the new items as much as possible in a balanced manner.
i.e. air conditioner 1 on one leg, the other on the other leg.
Monitor voltage. Campgrounds are endemic for low voltage. I shut down at 107 or add my autoformer to boost voltage.
It is good to check polarity and voltage under load before plugging in your RV.
The best of the add on energy management devices may be the Hughes PWD50-EPO-H Power Watchdog Smart Bluetooth Surge Protector Plus EPO with Auto Shutoff - 50 Amp Hardwire Version. The one thing I do not like is the cut out voltage which is at 104--to low for my comfort zone.
https://hughesautoformers.com/wp-conten........oads/2019/02/PWD-EPO-H-instructions.pdf
* This post was edited 07/28/20 03:46pm by pianotuna *
Regards, Don
