RV.Net Open Roads Forum: How to increase water flow AFTER the filters?
 > How to increase water flow AFTER the filters?
Page of 5
PA12DRVR
Back in God's Country
Posted: 07/28/20 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
Thoughts:
- I use a filter system at the house and at the cabin. No RV, but both locations have iron / smell issues.
- Carbon filter helps, but to eliminate the iron and the smell, I had to have a carbon filter upstream and the last downstream filter was an "RFFE" filter, the filter people simply called it an "iron filter".
- Recognizing that I don't use it on an RV, I'd suggest: a) taking out each filter in sequence and seeing how the water flow is affected; b) going with a 5 micron carbon filter as the upstream filter, an iron filter as the 2nd "midstream" filter and ditching the "metal trap canister"....although I'll admit to not knowing what that is, on both my house and cabin systems, I only have the two filters. If there was a "simple system" you used previously, try putting an iron filter as the downstream filter in that and see how it works out.
You've got a flow issue, so I'd also check the filter housings for physical impediments or a clogged orifice.
CRL
My RV is a 1946 PA-12
Back in the GWN
rk911
DuPage County
Posted: 07/28/20 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
darleyhavidson wrote:
rk911 wrote:
the 5-micron filter should allow more water to flow. one other thought...is the battey powering the pump fully charged? but i bet the larger filter will show an improvement in flow. but whether it meets your needs in terms of water quality is unknown.
My water source is from the campground well water system that supplies all camp sites. I connect the water hose to the "City Water" port on my RV and do not use the onboard water pump that pumps water from potable water holding tank.
I will try the bigger micron filter and see what happens...
ok, good. when you wrote "well" i ass-umed you were actually drawing from a well using a 12v exterior pump.
Rich
Ham Radio, Sport Pilot
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
darleyhavidson
North Dakota
Posted: 07/28/20 03:12pm Link  |  Quote  |  Print  |  Notify Moderator
PA12DRVR wrote:
Thoughts:
Thanks for the feedback. Your option "A" idea makes a lot of practical sense. Hopefully, it is something simple.
MFL
Midwest
Posted: 07/28/20 03:40pm Link  |  Quote  |  Print  |  Notify Moderator
I use a .5 micron carbon filter from the water filter store, in my single, but whole house filter system. My water pressure is the same with or without the filter installed (great pressure), using city hookup, or water pump.
I don't think going to a 5 micron filter is going to help.
Jerry
Wherever I happen to park
Posted: 07/28/20 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
The link holds 60 gallons. but you can get smaller ones (And larger ones) Camping world has some listed as well assorted sizes For you I would choose 15 or 30 with transfer pump
Water Bladder
Small storage space needed Also a towed to haul it
Home is where I park it.
TechWriter
On The Road
Posted: 07/28/20 04:49pm Link  |  Quote  |  Print  |  Notify Moderator
First, troubleshoot the system by removing one canister at a time and checking the pressure/flow after each removal.
Second, if you can't isolate the trouble by removing individual filters, then use a different strategy. Fill your water tank, turn off the external water source, and use your water pump to pump water from your tank. The pressure should be much better.
2001 Newmar Mountain Aire 4095 DP
Full Timer since May 2013
www.rvSeniorMoments.com
DISH TV for RVs
Bumpyroad
Virginia
Posted: 07/28/20 04:53pm Link  |  Quote  |  Print  |  Notify Moderator
I used two filters in parallel to get double the flow rate.
bumpy
azrving
Oatman
Posted: 07/28/20 05:31pm Link  |  Quote  |  Print  |  Notify Moderator
Dont confuse pressure with volume as you trouble shoot. If your pressure at the source is good then you have a flow/volume issue. Trouble shoot with a process of elimination. If you were to put a pressure gauge on the outlet side of the filters or at the faucet you should see the pressure as the same as at the source. When you open the faucet and the flow slows its an indication of a volume issue. .5 seems pretty small but as mentioned others have used them. Pressure is created at the pump and builds when you shut off the faucet. Again, volume and pressure are two different things. You say increase the pressure after the filters which you might think could be solved with an additional pump after the filter but it doesn’t work that way. You would then be restricting the intake flow to the pump. Some pumps are damaged by low intake flow because they can have cavitation
* This post was edited 07/28/20 05:50pm by azrving *
azrving
Oatman
Posted: 07/28/20 06:14pm Link  |  Quote  |  Print  |  Notify Moderator
Here’s another idea. I originally had a weeping toilet valve issue which I figured was a spec of sand or dirt in the valve seat. That’s when I installed two Home Depot GE filters. One is sort of a woven cloth and the other is carbon and I’ve had no more toilet issues. We then bought a Berkey Traveler water filter set up. Its a little smaller than the regular model and serves two people well. The two primary filters last a long time and two additional filters can be used to take out much smaller stuff. You could still use whatever part of your filter system that would take the grit and other stuff out. The Berkey is a very good filter
The Berkey can sit near the edge of the counter or they sell an optional chrome steel stand to set it on so its high enough to fill a cup or whatever
down home
south
Posted: 07/28/20 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
Did you flush the fines from each filter before connecting the next one in the series?
I have not run three but have run two in series. Perhaps and only perhaps this is contributing to partial blockage or restriction. On thing I have doe in fill the tank when pressure is low then use from the tank. Our last water pump would kick in when it was on and water pressure from the outside source was low and bring pressure up. This new identical pump not quite the same even though rated at 55 psi. Does your coach have its own pressure requlator somewhere set to 45psi?
Page of 5
